[postgis-devel] RFC - Orientation checking and forcing functions
Paul Ramsey
pramsey at cleverelephant.ca
Tue Feb 7 18:02:23 PST 2017
+1 from me
P.
> On Feb 7, 2017, at 4:55 PM, Daniel Baston <dbaston at gmail.com> wrote:
> Hi All,
> I put together a pull request a couple of weeks ago that introduces four functions for checking and forcing geometry orientation. The intent is to provide a less-ambiguous alternative to ST_ForceRHR, and an alternative to ST_Orientation that does not depend on SFCGAL. Strk asked that I bring this up on the devel list for a review of the semantics.
> The four proposed functions are.
> ST_ForceCW
> ST_ForceCCW
> ST_IsCW
> ST_IsCCW
> The semantics are straightforward, in my opinion:
> 1. ST_ForceCW is a synonym for ST_ForceRHR, which gives all exterior rings a clockwise orientation and all interior rings a counterclockwise orientation. Non-polygonal geometries, including closed LineStrings, are simply passed through.
> 2. ST_ForceCCW is simply a shorthand for ST_Reverse(ST_ForceCW)
> 3. ST_IsCW returns true if a geometry would not be modified by ST_ForceCW. It is essentially a synonym for ST_OrderingEquals(geom, ST_ForceCW(geom)).
> 4. ST_IsCCW returns true if a geometry would not be modified by ST_ForceCCW.
> A few notes:
> ST_IsCW and ST_IsCCW both return false if a polygon has invalid ring orientation (i.e., exterior and interior rings are all clockwise)
> ST_IsCW and ST_IsCCW both return true for geometries that have no non-empty polygonal components.
> Relevant links:
> PR: https://github.com/postgis/postgis/pull/122
> Trac: https://trac.osgeo.org/postgis/ticket/3689, https://trac.osgeo.org/postgis/ticket/3651
> Dan
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170207/f0ce8ed9/attachment.html>
