[postgis-devel] Recheck on Points broken
Regina Obe
lr at pcorp.us
Tue Jan 3 04:54:48 PST 2017
>> Anyrate if there is nothing that can be done about ensuring index
>> distance is always less or equal to actual distance
> I remember we were all happy about having *real* distance with a more recent PostgreSQL. If that's not the case (as the user reports) we should try to find a way to provide both mechanisms.
> Two different operators, maybe ?
> --strk;
We've already got two different operators. We have <#> which doesn't use recheck and that's what I told the user to use, until we resolve this.
The thing is the <-> I think pretty much for all reasonable purposes returns the right order for points (and in fact in this case yields the same value and <-> I think in all cases it will).
So it's just the float4/float8 mess why it screws up and it Errors noisily in PostgreSQL land where we cannot control.
I hate telling people to if you have point / point use <#> and if you have others you can safely use <->. That's sooo unfriendly.
I think the best thing is just to not have point-point checks use recheck. Can we do that easily? That's what PostgreSQL point/point does.
That way we don't fall into the PostgreSQL box trap of
"Hey -- how come your index distance is bigger than your computed distance. What kind of monster are you? Screw you!"
Thanks,
Regina
