[postgis-devel] Docs broken for other languages
George Silva
georger.silva at gmail.com
Tue Jan 31 11:33:52 PST 2017
I needed to run ./autogen first, then the ./configure file showed up.
Now I have run configure.
The pull-tx command is running again, just to be sure. (I used the same
command that is described in the makefile, but..)
After that let's see if I can run make html-localize :D
Thanks
On Tue, Jan 31, 2017 at 5:18 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Jan 31, 2017 at 04:02:19PM -0200, George Silva wrote:
> > george at winterfell ~/projetos/postgis/doc $ make html-localized
> > make: *** No rule to make target 'html-localized'. Stop.
> > george at winterfell ~/projetos/postgis/doc $ make pull-tx
> > make: *** No rule to make target 'pull-tx'. Stop.
> Did you run ./configure from the top-level dir ?
> You'd get that message in absence of a Makefile
> (which is generated by ./configure from Makefile.in)
> > I'm a little green with makefiles :D
> First step is *having* a Makefile, see if you can get there :)
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170131/ca046e8f/attachment.html>
