[postgis-devel] [postgis-tickets] r15439 - Clean up of formatting of r15406.
Regina Obe lr at pcorp.us
Wed Jun 21 04:29:42 PDT 2017
Done -   I put in an alias though.
I like aliases so I don't have to figure out where the geom came from or get
bitten when someone introduces another variable somewhere called geom.
@@ -236,7 +236,7 @@
   -- definition by splitting
   FOR rec IN SELECT id(tg), alayer as lyr,
-    geom, ST_Dimension(geom) as dims
-    FROM (SELECT gd.geom FROM ST_Dump(ageom) AS gd ) as f
-    WHERE NOT ST_IsEmpty(geom)
+    geom, ST_Dimension(gd.geom) as dims
+    FROM ST_Dump(ageom) AS gd
+    WHERE NOT ST_IsEmpty(gd.geom)
   LOOP
-----Original Message-----
Sent: Wednesday, June 21, 2017 6:15 AM
To: Regina Obe <lr at pcorp.us>
Cc: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-tickets] r15439 - Clean up of formatting of r15406.
On Tue, Jun 20, 2017 at 04:29:37PM -0700, Regina Obe wrote:
> --- trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-20 22:16:18
UTC (rev 15438)
> +++ trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-06-20 23:29:37
UTC (rev 15439)
> @@ -236,16 +236,24 @@
> -    FROM (SELECT (ST_Dump(ageom)).geom) as f
> +    FROM (SELECT gd.geom FROM ST_Dump(ageom) AS gd ) as f
How about this simplification:
       FROM ST_Dump(ageom)
--strk;
