[postgis-devel] Allowing use of PostGIS EXTENSION w/out raster
'Sandro Santilli'
strk at kbt.io
Mon Oct 9 00:41:14 PDT 2017
On Sun, Oct 08, 2017 at 11:29:33PM -0400, Regina Obe wrote:
> Sandro Santilli <strk at kbt.io>> writes:
>> The proposals are:
>> 1) Move raster to its own extension "postgis_raster"
>> See https://trac.osgeo.org/postgis/ticket/3888
>> 2) Provide two versions of extension "postgis"
>> See https://trac.osgeo.org/postgis/ticket/3890
> I think approach 2 is better for packagers because a user can more
> cleanly migrate to a postgis that doesn't have raster without knowing
> anything.
Could you elaborate on this ? It looks to me that:
- How do users migrate to postgis that doesn't have raster ?
proposal 1: ALTER EXTENSION postgis UPDATE TO '<x>noraster'
proposal 2: DROP EXTENSION postgis_raster
Given the above, user needs to know the value of <x> with proposal 1
while it doesn't with proposal 2. Or did you mean upon upgrade ?
> I am against option (1) because as it stands it breaks
> backward-compatibility in a huge way, both in upgrading your database
> and having different instructions for enabling raster support in your
> database.
I agree proposal 1 is not backward compatible in terms
what you get under the "postgis" extension name.
As for instructions I don't think it's a big deal, there are
already instructions to create multiple extensions (topology):
http://postgis.net/docs/manual-2.4/postgis_installation.html#create_new_db_extensions
and enabling raster is already a separate step for non-extension
install:
--strk;
