[postgis-devel] ST_SimplifyVW not touching Start and endpoint of polygon
Nicklas Avén nicklas.aven at jordogskog.no
Sun Oct 15 23:19:05 PDT 2017
On Mon, 2017-10-16 at 08:12 +0200, Sandro Santilli wrote:
> But on the other hand I do see reasons for you wanting to
> maintain the start/end points (in topology building, for
> example, where the start/end point may be a node in a bigger
> topology, so please if you allow for changing that make it
> an option exposed at SQL level.
> --strk;
Good point, I agree it should be just an option if done.
Also important to maintain the non-collapsing functionality.
How does ST_Simplify handle this? Does ST_Simplify move start/end -
point?
/Nicklas
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
