[postgis-devel] PostGIS 2.2.6, 2.3.4, and 2.4.1
Sandro Santilli
strk at kbt.io
Fri Oct 20 08:23:19 PDT 2017
On Fri, Oct 20, 2017 at 05:57:13AM -0700, Paul Ramsey wrote:
> I think this is something that has only been biting me, and only recently
> (not sure what changed, versionwise, maybe glibtoolize behaviour). I
> reflexively run ./make_dist.sh inside the svn directory I'm work with,
> which already has install-sh installed. make_dist pulls the source, goes
> into that directory and runs ./autogen.sh, and glibtoolize then does *not*
> bring in install-sh because there's already a copy.... one directory level
> higher.
I can reproduce here with libtool 2.4.6.
Run with -verbose flag it says:
libtoolize: putting auxiliary files in '..'.
Instead of:
libtoolize: putting auxiliary files in '.'.
When ../install-sh exists
Would you file a ticket for this problem ?
Seems to be fixed by adding this to configure.ac:
AC_CONFIG_AUX_DIR(.)
--strk;
