[postgis-devel] [postgis-users] PostGIS 2.4.0beta1 is released
Greg Troxel
gdt at lexort.com
Sat Sep 2 11:13:20 PDT 2017
"Regina Obe" <lr at pcorp.us> writes:
> The PostGIS development team is pleased to announce the release of PostGIS
> 2.4.0beta1.
I tested on NetBSD 7, amd64, with (because that's what was installed):
PostgreSQL 9.3.18 on x86_64--netbsd, compiled by gcc (nb2 20150115) 4.8.5, 64-bit
Postgis 2.4.0beta1 - r15614 - 2017-09-02 16:57:24
scripts 2.4.0beta1 r15614
GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
PROJ: Rel. 4.9.3, 15 August 2016
and tests passed, modulo two "interrupted late" issues, similar to those
I reported long ago with 2.3.x (and didn't ever pursue hard enough to
fix).
I see that two of my patches to fix Makfeile usage of $(PERL) (to be
@PERL@ from postgis configure, not pgxs denoting what was found at pgsql
configure time, when pkgsrc hides perl because it isn't declared as a
dependency) are in this release. If this were a real release and I
committed an update to pkgsrc, there would be no patches!
(The tarball postgis-2.4.0beta1.tar.gz unpacked to the directory
postgis-2.4.0beta1, which is appreciated and made this testing easier
and more reliable -- by staying within the packaging system I'm using the
exact steps that would happen with a release, modulo the version
number.)
Two warnings that I don't remember from before and seem not quite right:
build:
gcc -I../../liblwgeom -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -fPIC -DPIC -Wall -Wmissing-prototypes -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -c -o rt_raster.o rt_raster.c
rt_raster.c: In function 'rt_raster_to_gdal_mem':
rt_raster.c:1966:4: warning: implicit declaration of function 'strnicmp' [-Wimplicit-function-declaration]
if (strnicmp(pszDataPointer, "0x", 2) == 0)
I think this is #defined to strncasecmp, which needs <strings.h>
check:
(I realize this is some kind poor man's polymorphism, but given that
this is C I would expect some kind of inline function (or maybe a macro)
to do type-safe casting. I admit to not reading the make check output
from earlier versions.)
gcc -O2 -D_FORTIFY_SOURCE=2 -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -Wall -Wmissing-prototypes -I/usr/pkg/include -I/usr/pkg/include -I/usr/include -I/usr/pkg/include/freetype2 -I/usr/include/krb5 -I.. -c -o cu_algorithm.o cu_algorithm.c
cu_algorithm.c: In function 'test_lwpoly_construct_circle':
cu_algorithm.c:1118:2: warning: passing argument 1 of 'lwgeom_count_vertices' from incompatible pointer type [enabled by default]
ASSERT_INT_EQUAL(lwgeom_count_vertices(p), segments_per_quad * 4 + 1);
In file included from ../liblwgeom_internal.h:48:0,
from cu_algorithm.c:17:
../liblwgeom.h:1258:12: note: expected 'const struct LWGEOM *' but argument is of type 'struct LWPOLY *'
extern int lwgeom_count_vertices(const LWGEOM *geom);
cu_algorithm.c:1121:4: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
g = lwgeom_get_bbox(lwpoly_as_lwgeom(p));
cu_algorithm.c:1127:2: warning: passing argument 1 of 'lwgeom_area' from incompatible pointer type [enabled by default]
CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(p), M_PI*5*5, 0.1);
../liblwgeom.h:1180:15: note: expected 'const struct LWGEOM *' but argument is of type 'struct LWPOLY *'
extern double lwgeom_area(const LWGEOM *geom);
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170902/e1eebb86/attachment.sig>
