[postgis-devel] PSC Vote: Change PostGIS library name to drop the minor
Regina Obe lr at pcorp.us
Tue Sep 5 13:12:00 PDT 2017
> On Tue, Sep 05, 2017 at 10:57:41AM -0400, Regina Obe wrote:
> > What if a user wants to pg_upgrade from 9.4 to 10?
> The simplest way would be dump & restore (aka "hard upgrade").
> It's what pg_upgrade does anyway, we found out, no ?
>> --strk;
It uses dump /restore but I believe only to reconstitute the data tables, types, and functions.
The data itself is just moved.
That's why a pg_upgrade of a multi-terabyte database can be done in a few minutes as opposed to a few hours or days.
It also has the option of linking structures so if you are short on disk space you can use it to move your data if you can't hold two versions of your data.
Admittidly I haven't tried that since linking sounds like a scary thing to me.
