[postgis-devel] geom_name
Björn Harrtell bjorn.harrtell at gmail.com
Thu Sep 7 13:34:07 PDT 2017
So we are agreed that there will be no signature change? Instead I will
work towards an implementation and documentation change for geom_name to
the following:
"geom_name is the name of the geometry column in the row data. If NULL it
will default to use the first geometry column in the row data."
/Björn
2017-09-07 21:08 GMT+02:00 Paul Ramsey <pramsey at cleverelephant.ca>:
> Yes, take the first one unless the geom_name is provided. So geom_name
> would default to NULL and NULL would mean “the first one you find"
> P
> On Sep 7, 2017, at 12:06 PM, Regina Obe <lr at pcorp.us> wrote:
> Just to add to this to make sure I'm following:
> For this question:
> > Also, a bit late in the day, but why the text parameter "geom_name" in
> these various signatures, instead of automagically finding it in the row?
> > P
> Is it ever possible that an MVT row could have more than one geometry
> column.  I assume so.  If so I think it might be good to keep the geom_name
> field though perhaps make it a default option and in that case it picks the
> first one it finds.  Similar to how we do pgsql2shp where you can
> explicitly set the geometry column or have pgsql2shp do it's thing and just
> pick the first one it finds.
> Thanks,
> Regina
> *From:* Regina Obe [mailto:lr at pcorp.us <lr at pcorp.us>]
> *Sent:* Thursday, September 07, 2017 2:57 PM
> *To:* 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>;
> 'Björn Harrtell' <bjorn at wololo.org>
> *Cc:* 'Paul Ramsey' <pramsey at cleverelephant.ca>
> *Subject:* RE: [postgis-devel] geom_name
> > We should ask about API changing, I'm sure Regina would say we're done,
> which effectively means done-for-all-time, since changing public function
> signatures is basically impossible one they are done.
> > P
> I'm fine with you changing the API now before final 2.4.0 release.  I
> promised no new functions, not no new API changes to new 2.4 functions.
> I think it would be good to drop the old signature in the
> postgis_drop_before.sql  since some people have already started using the
> MVT functions.
> If it impacts existing code, we should also put in BREAKING CHANGE for
> postgis -2.4.0  the change so people are warned and know how to change
> their code if they were using an earlier postgis 2.4.0dev
> Thanks,
> Regina
> On Thu, Sep 7, 2017 at 10:45 AM, Björn Harrtell <bjorn.harrtell at gmail.com>
> wrote:
> Hi Paul,
> No good reason except that I couldn't find out a deterministic way to find
> it and put it out of my mind after that. :(
> With some guidance I'll be happy to revise the API if it's not too late at
> this point.
> /Björn
> 2017-09-07 19:41 GMT+02:00 Paul Ramsey <pramsey at cleverelephant.ca>:
> P
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170907/446f8f15/attachment.html>
