[postgis-devel] ORDER BY semantic on geometries
Sandro Santilli
strk at kbt.io
Wed Sep 13 00:32:11 PDT 2017
On Tue, Sep 12, 2017 at 04:13:31PM -0700, Regina Obe wrote:
> Author: robe
> Date: 2017-09-12 16:13:31 -0700 (Tue, 12 Sep 2017)
> New Revision: 15703
> + - B-Tree index operators < = > changed to provide better spatial locality on sorting
> + and have expected behavior on GROUP BY.
> + If you have btree index for geometry or geography, you need to REINDEX it, or review
> + if it was created by accident and needs to be replaced with GiST index.
> + If your code relies on old left-to-right box compare ordering,
> + update it to use << >> operators
As also written in the ticket, << and >> operators don't provide
left-to-right box ordering.
Is the new operator working as expected ? A test should be added.
I tried this:
with inp(g) as ( VALUES
( 'LINESTRING(0 0, 10 0)'::geometry ),
( 'LINESTRING(2 0, 12 0)'::geometry ),
( 'LINESTRING(10 0, 0 0)'::geometry ),
( 'LINESTRING(2 1, 12 -1)'::geometry )
select 'order1', ST_AsText(g)
FROM inp ORDER BY g;
And obtained this:
order1|LINESTRING(0 0,10 0)
order1|LINESTRING(10 0,0 0)
order1|LINESTRING(2 1,12 -1)
order1|LINESTRING(2 0,12 0)
--strk;
