[postgis-devel] [postgis-tickets] r15723 - #3847, coverity fixes in topology and address standardizer
Sandro Santilli
strk at kbt.io
Thu Sep 14 07:19:56 PDT 2017
On Thu, Sep 14, 2017 at 06:56:57AM -0700, Paul Ramsey wrote:
> Author: pramsey
> Date: 2017-09-14 06:56:57 -0700 (Thu, 14 Sep 2017)
> New Revision: 15723
> Modified:
> trunk/extensions/address_standardizer/gamma.c
> trunk/topology/postgis_topology.c
> Log:
The change below seems to be calling SPI_prepare on each and every
call (previously it was only called on first invocation).
> Modified: trunk/topology/postgis_topology.c
> --- trunk/topology/postgis_topology.c 2017-09-14 13:52:25 UTC (rev 15722)
> +++ trunk/topology/postgis_topology.c 2017-09-14 13:56:57 UTC (rev 15723)
> @@ -170,21 +170,19 @@
> static SPIPlanPtr plan = NULL;
> // prepare
> - if ( ! plan ) {
> - sql = "SELECT id,srid,precision,null::geometry"
> - " FROM topology.topology "
> - "WHERE name = $1::varchar";
> - argtypes[0] = CSTRINGOID;
> - plan = SPI_prepare(sql, 1, argtypes);
> - if ( ! plan )
> - cberror(be, "unexpected return (%d) from query preparation: %s",
> - SPI_result, sql);
> - return NULL;
> - SPI_keepplan(plan);
> - // SPI_freeplan to free, eventually
> + sql = "SELECT id,srid,precision,null::geometry"
> + " FROM topology.topology "
> + "WHERE name = $1::varchar";
> + argtypes[0] = CSTRINGOID;
> + plan = SPI_prepare(sql, 1, argtypes);
> + if ( ! plan )
> + cberror(be, "unexpected return (%d) from query preparation: %s",
> + SPI_result, sql);
> + return NULL;
> + SPI_keepplan(plan);
> + // SPI_freeplan to free, eventually
Or am I missing anything ?
--strk;
