[postgis-devel] [postgis-users] PostGIS 2.4.0rc2 released
Sandro Santilli strk at kbt.io
Tue Sep 26 06:29:34 PDT 2017
On Tue, Sep 26, 2017 at 09:19:49AM -0400, Greg Troxel wrote:
> My overall suggestion is to back out this change, as it doesn't fix a
> bug in the beta1/rc1/etc.  (Really, just to drop the no-trailing-blanks
> token from the check dependencies.)
Before doing that, could you check current tip of branch ?
It should fix the .gitignore handling and the exclusion of
generated files. Use of -P switch is still an issue though,
but should easy to remove replacing it with:
    grep -n '[[:space:]]$'
--strk;
