[postgis-devel] PostGIS 2.5 what should be minimum requirements?
Regina Obe lr at pcorp.us
Fri Sep 29 13:28:50 PDT 2017
Bborie,
Looking forward to it. I miss you :)
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bborie Park
Sent: Friday, September 29, 2017 1:56 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] PostGIS 2.5 what should be minimum requirements?
+1 for the above. I'm hoping to get back into the mess in November/December with a focus on parallelism/performance and 9.6 will be required.
On Fri, Sep 29, 2017 at 7:40 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
While we are still in infancy of PostGIS 2.5 (and probably at least a year
away from release), I'd like to get requirements out of the way and propose
the following:
1) Drop support for PostgreSQL 9.4 and 9.5  (so PostgreSQL 9.6 - PostgreSQL
11 will be supported)
9.4 has the main annoyance of not supporting true KNN and I'm tired of
explaining this to folks and having people with pg_upgrading from these
lowers being screwed when upgrading because they can no longer do
ALTER EXTENSION ...  cause they are already at 2.5.0
9.5 doesn't support Parallelism and I suspect we may need to do some
restructuring for some aggs in 2.5, I'd just assume not have to make special
concessions for folks trying to pg_upgrade from a PostgreSQL 9.5 2.5
extension to 9.6+
2) Make GEOS 3.5+ the minimum (for 2.4  GEOS 3.4 was the minimum)  - we've
got too much stuff that requires 3.5 already that is turned off for lower
and newer GEOS has some robustness improvements.
3) Make Proj 4.9+ the minimum currently our minimum is proj 4.7 I think.  As
discussed it's on the table to redo some of the geography stuff like
ST_Segmentize using proj 4.9+ features.
Anyone have issues with the above?
PSC folks, if you are okay with all the above please give a +1
If you are okay with some and not others, I can break apart so we can at
least decide on some pieces.
Thanks,
Regina
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170929/2a2de84f/attachment.html>
