[postgis-devel] PostGIS 2.5 what should be minimum requirements?
Greg Troxel
gdt at lexort.com
Sat Sep 30 11:47:07 PDT 2017
Mateusz Loskot <mateusz at loskot.net> writes:
>> There isn't agreement about whether it is a bug for packages to use the
>> GEOS C++ API. If it really is a bug, GEOS is buggy for installing the
>> headers.
> Please, can we stop this heresy?
> I'm tired of explaining GEOS C++ API status.
So do you agree with this, taken from the geos README (in 3.6.2):
### Using the C++ interface (discouraged)
NB: The C++ interface should not be used directly; the GEOS project
views it as a bug for another program to use the C++ interface or even
to directly link against the C++ library. The C++ library name will
change on every minor release because it is too hard to know if there
have been ABI changes. (The C library uses the C++ interface, but the
C library follows normal ABI-change-sensitive versioning, so programs
that link only against the C library should work without relinking
when GEOS is upgraded.)
To compile programs against the C++ lib:
CFLAGS += `geos-config --cflags`
LDFLAGS += `geos-config --ldflags` -lgeos
#include <geos.h>
Basic usage examples can be found in `doc/example.cpp`.
Or do you think something else? It genuinely seems to me that there are
multiple opinions out there.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170930/b14d4062/attachment.sig>
