[postgis-devel] different result ST_Tesselate from invalid polygon that ST_IsValid says is valid
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed Apr 25 06:26:11 PDT 2018
For the record:
I meant to say that disabling the validity check in sfcgal can dramatically
*de*-crease processing time (not increase).
On Wed, Apr 25, 2018 at 1:36 PM, Nicklas Avén <nicklas.aven at jordogskog.no>
wrote:
> Hello Tom
> Thanks a lot. That might be the problem. I see that I have libSFCGAL
> libraries in my /usr/local path so I have probably built it manually
> some time, and probably without validity check. On the server that is
> protesting I use the Debian package.
> I will try to build it manually on the server too without validity
> check.
> Thanks!
> Nicklas
> On Wed, 2018-04-25 at 13:26 +0200, Tom van Tilburg wrote:
> > Hi Nicklas,
> > I have the same issue on "POSTGIS=""2.5.0dev r16509"" [EXTENSION]
> > PGSQL=""100"" GEOS=""3.6.2-CAPI-1.10.2 4d2925d6"" SFCGAL=""1.3.1""
> > PROJ=""Rel. 4.9.3, 15 August 2016"" GDAL=""GDAL 2.2.3, released
> > 2017/11/20"" LIBXML=""2.9.4"" LIBJSON=""0.12.1""
> > LIBPROTOBUF=""1.2.1"" RASTER (sfcgal procs from ""2.5.0dev r16327""
> > need upgrade)"
> > Likely the error comes from the validity check in sfcgal:
> > https://github.com/Oslandia/SFCGAL/blob/561c301a24a76425716ec321d1c5b
> > 2229b9e1bd2/src/algorithm/isValid.cpp#L284
> > I know that during the build-time of sfcgal you can disable the
> > validity-check (which can dramatically increase your processing time)
> > so maybe you have one version where this option has been disabled at
> > build?
> > Best,
> > Tom
> > On Tue, Apr 24, 2018 at 10:24 PM, Nicklas Avén <nicklas.aven at jordogsk
> > og.no> wrote:
> > > Thanks Martin!
> > > I realize you of course are right when looking closer on it. It was
> > > all those intersections between the holes and boundary that made me
> > > think so.
> > > But it is actually 3 holes :-)
> > > Then I guess that the error message comes from libcgal and probably
> > > boost when running st_tesselate.
> > > So then my confusion moves to why ST_Tesselate works on 1 computor
> > > but not on another with same OS, same versions of PostGIS code.
> > > I also don't fully understand the error message:
> > > ERROR: Polygon is invalid : interior is not connected
> > > Since it is all integer values I don't understand that there should
> > > be any machine dependent differences when judging validity.
> > > This is about the packaging of TilelessMap. I have to find a better
> > > way of doing the triangulation since, in the end I don't want the
> > > triangle coordinates but just their index in the boundary.
> > > It is the ugly scripts here that I need to find a way to handle
> > > invalid geometries and ugly geometries like this.
> > > https://github.com/TilelessMap/pg_tileless
> > > Thanks
> > > Nicklas
> > > On Tue, 2018-04-24 at 12:39 -0700, Martin Davis wrote:
> > > > It's ugly, but it is valid according to SFS rules (which is what
> > > > JTS/GEOS/PostGIS implement).
> > > > Why do you think it is not valid?
> > > > On Tue, Apr 24, 2018 at 11:48 AM, Nicklas Avén <nicklas.aven at jord
> > > > ogskog.no> wrote:
> > > > > Hello
> > > > > I have an ugly polygon, presented as wkt here below.
> > > > > It is really ugly, and from what I understand it has
> > > > > selfintersection
> > > > > and other things taht I expected ST_Isvalid to react on.
> > > > > But ST_Isvalid let's it through.
> > > > > And on 2 of my PostGIS installations ST_Tesselate gives a
> > > > > reasonable
> > > > > answer. But on a third installation on a virtual machine at
> > > > > Linode I
> > > > > get an error message which I am not sure where it comes from.
> > > > > It says:
> > > > > Does that come from boost?
> > > > > So this is 2 questions:
> > > > > 1) Why doesn't ST_Isvalid tell me it is invalid
> > > > > 2) Where should I search for the different results?
> > > > > As far as I can find I have the exactly same versions on
> > > > > everything on
> > > > > the installs.
> > > > > POSTGIS="2.5.0dev r16554" [EXTENSION] PGSQL="100"
> > > > > GEOS="3.7.0dev-CAPI-
> > > > > 1.11.0 r" SFCGAL="1.3.0" PROJ="Rel. 4.9.3, 15 August 2016"
> > > > > GDAL="GDAL
> > > > > 2.1.2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1"
> > > > > RASTER
> > > > > (1 row)
> > > > > and boost version seems to be the same
> > > > > Package: libboost-system1.62.0
> > > > > Could someone else with sfcgal enabled see what result they
> > > > > get?
> > > > > select st_tesselate(
> > > > > 'POLYGON((389923 6365025,390094 6364730,390269 6364430,390261
> > > > > 6364415,390250 6364399,390239 6364372,390207 6364367,390168
> > > > > 6364372,390136 6364377,390100 6364393,390081 6364429,390070
> > > > > 6364458,390059 6364474,390059 6364494,390044 6364497,390019
> > > > > 6364506,390012 6364512,389985 6364533,389973 6364545,389951
> > > > > 6364567,389931 6364588,389927 6364598,389912 6364628,389907
> > > > > 6364636,389883 6364647,389870 6364649,389863 6364638,389858
> > > > > 6364613,389851 6364591,389817 6364575,389795 6364594,389792
> > > > > 6364625,389791 6364653,389796 6364679,389802 6364695,389811
> > > > > 6364722,389840 6364741,389868 6364741,389882 6364721,389900
> > > > > 6364705,389915 6364699,389915 6364717,389909 6364737,389891
> > > > > 6364770,389885 6364781,389867 6364798,389845 6364810,389823
> > > > > 6364809,389801 6364815,389778 6364822,389761 6364822,389742
> > > > > 6364840,389732 6364863,389741 6364890,389741 6364919,389744
> > > > > 6364920,389760 6364932,389768 6364940,389774 6364954,389776
> > > > > 6364963,389787 6364970,389816 6364981,389852 6364993,389895
> > > > > 6365011,389923 6365025),(390094 6364730,389987 6364914,389981
> > > > > 6364904,389971 6364887,389947 6364869,389921 6364853,389895
> > > > > 6364832,389892 6364816,389906 6364812,389941 6364818,389973
> > > > > 6364827,390021 6364852,390094 6364730),(390094 6364730,390050
> > > > > 6364714,390050 6364713,390094 6364730),(390050 6364714,390034
> > > > > 6364736,390014 6364733,389982 6364724,389954 6364721,389953
> > > > > 6364710,389958 6364695,389964 6364677,389972 6364672,389988
> > > > > 6364673,390015 6364678,390041 6364695,390049 6364713,390047
> > > > > 6364713,390050 6364714))'::geometry);
> > > > > Thanks
> > > > > Nicklas
> > > > > _______________________________________________
> > > > > postgis-devel mailing list
> > > > > postgis-devel at lists.osgeo.org
> > > > > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180425/9d5a1f98/attachment-0001.html>
