[postgis-devel] Making SFCGAL mandatory
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat Dec 1 02:59:17 PST 2018
I've started removing SFCGAL function clones.
ST_Area is committed to trunk, ST_Distance is similarly going to be
https://github.com/postgis/postgis/pull/347/files
Overlay functions to follow. If you have any precious query example that
does not work without SFCGAL, it's really time to get it into test suite
(or at least this thread), before those get removed and "we never promised
*that* will work". I've checked 2D TINs on ST_Area manually and it worked
even on my 2.5. On the other hand, SFCGAL just barfs on CIRCULARSTRING, so
removing SFCGAL there seems to *add* features.
ср, 28 нояб. 2018 г. в 18:28, Regina Obe <lr at pcorp.us>:
> > It looks fine to me as well.
> > I also agree we better find a semantic difference between function names,
> > rather than just adding a "SFCGAL" prefix or suffix.
> > The main difference is that SFCGAL handles TIN/PolyhedralSurfaces and is
> > able to work with them either as meshes or as volumes (if the mesh is
> closed).
> > So for functions that overlap and are handled by the backend switch that
> we
> > would like to avoid, what about something like ST_3DIntersection() that
> > becomes ST_3DMeshIntersection() + ST_3DVolumeIntersection() in
> > postgis_sfcgal.so ? With similar prefix "mesh" and "volume" for union,
> > difference, intersects.
> [Regina Obe]
> I like that idea. ST_3DIntersection I wasn't so concerned with because
> PostGIS core doesn't have that at all,
> Though I like the semantic difference between the two.
> Maybe we can mark ST_3DIntersection as deprecated
> > About 2D intersection handled by SFCGAL, the only added value is the
> > handling of TIN/PS. But do we really need such things in 2D only ?
> [Regina Obe]
> That's what I thought the difference was too and I would say probably not.
> I can't think of a reason why people want to manage 2D TIN / 2D
> polyhedralsurfaces just cause they exist.
> > There is also a SFCGAL ST_Area(), but I can't remember what it adds ...
> [Regina Obe]
> I haven't tried, maybe it works for TINs where as the PostGIS one
> definitely doesn't.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181201/564008e3/attachment.html>
