[postgis-devel] GDAL and Proj versions for PostGIS 3
Darafei "Komяpa" Praliaskouski me at komzpa.net
Mon Dec 17 07:54:37 PST 2018
пн, 17 дек. 2018 г. в 15:23, Even Rouault <even.rouault at spatialys.com>:
> > For using proj6 in full looks like it requires redesign in
> spatial_ref_sys
> > table, dropping it non-user part of it and relying on internal proj6
> > database?
> That's a good question. You could at least conceptually imagine to
> dynamically
> populate part of the table: perhaps foreign table mechanism to
> automatically
> generate entries that come from the PROJ database by using the PROJ API,
> normal table for the user entries, and spatial_ref_sys being a view of the
> two
So, what we have now in spatial_ref_sys:
 - EPSG and other registries codes and their proj4text.
 - some user entries.
 - internal entries for _ST_BestSRID or how is it called, to perfrom
geography-by-geometry-engine.
 - clever users editing preexisting entries.
 - I think there are some manual patches over the database.
Who needs it:
 - ST_Transform, to know how to transfrom.
 - userland software that wants to know what is that they just read from db.
 - I'm not sure what happens in Raster.
I just want to warn that iterating over all CRS from the PROJ database and
> export them as WKT and PROJ string takes a few seconds, so the above would
> only perform well if clever instanciation can be done (that is if you do
> SELECT * FROM spatial_ref_sys WHERE srid = 12345, only 12345 will only be
> generated on the fly)
Can we live without proj at all? I believe most web map cases are covered
by SRID 0, 4326, 3857, 900913 and rarely 3395. All those have
transformations in one-two lines of math.
If we can do some wrapper similar to what LWGEOM does to GEOS, I think then
we can survive the migration and juice some performance profits from it.
> > Looks like we have to do it since proj7 is going to drop old way.
> You could still have a full spatial_ref_sys table. It is just that it has
> a
> risk of being unsynchronized with the PROJ database.
What happens if it is? How large is error margin, who is affected?
Another thing to be aware of is that the generated WKT1 and PROJ strings
> will
> now lack in a lot of cases the TOWGS84 clause when there are several
> candidate
> datum transformations from the CRS to WGS84 (previously the libgeotiff
> script
> that created the GDAL .csv files would select the TOWGS84 transform whose
> area
> of use was the largest). The new way will be to pass to
> proj_create_crs_to_crs() an optional area of interest, and it will
> determine
> from the database the more appropriate datum transformation.
> You also have the question to which part of the spatial_ref_sys entry you
> consider authoritative. The auth_name+auth_srid, the srtxt, the proj4text
> Currently PostGIS must certainly use the proj4text to use pj_init*() +
> pj_transform(). With PROJ 6, you can potentially use the 3 possibilities
> with
> proj_create_crs_to_crs(), but if you use the proj4text, you will not be
> able
> to benefit from the late-binding capabilities.
Can we add a constraint to have just one of them filled at all times?
> > Looks like PostGIS is going to have mandatory transitive SQLite
> dependency
> > via Proj.
> Yes
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181217/38a151e7/attachment-0001.html>
