[postgis-devel] Error in make test - libpg
Bruce Rindahl bruce.rindahl at gmail.com
Mon Dec 17 21:08:56 PST 2018
Running make test.  All tests OK until loader when I ran unto this:
---- Making check in loader
make[1]: Entering directory '/home/pi/postgis-3.0.0dev/loader'
make -C cunit check
make[2]: Entering directory '/home/pi/postgis-3.0.0dev/loader/cunit'
/home/pi/postgis-3.0.0dev/loader/cunit/.libs/lt-cu_tester: error while
loading shared libraries: libpq.so.5: cannot open shared object file: No
such file or directory
Makefile:80: recipe for target 'check' failed
llibpq.so.5 is at /usr/local/pgsql/lib/libpq.so.5 at the standard location
from the postgresql 11.1 install.  Suggestions?
Thanks
Bruce
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181217/803a9964/attachment.html>
