[postgis-devel] Documentation on make check
Darafei "Komяpa" Praliaskouski me at komzpa.net
Tue Dec 18 03:00:59 PST 2018
Hi Bruce,
I'm happy that I'm not the only one building PostGIS on raspberry pi.
Can you perform your proposed edit on the docs so we can merge those?
Just find the doc/installation.xml file on github and push [Edit] button on
the top.
https://github.com/postgis/postgis/blob/9fe22540a97cdc94ef41d438b990b6a1dcfe169b/doc/installation.xml#L679
вт, 18 дек. 2018 г. в 07:16, Bruce Rindahl <bruce.rindahl at gmail.com>:
> Doing some full compilation and checking on raspberry pi.  While running
> make check, realized this has to be run as a postgresql superuser.  Suggest
> adding to documentation it be run as:
> PGUSER=foo make check
> where foo is a superuser.
> POSTGIS="3.0.0dev r17106" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1
> 27a5e771" PROJ="Rel. 5.2.0, September 15th, 2018" LIBXML="2.9.4"
> Thanks
> Bruce
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181218/e23feaef/attachment-0001.html>
