[postgis-devel] RectDistance
Nicklas Aven nicklas.aven at jordogskog.no
Tue Feb 20 11:38:32 PST 2018
Hurray, sounds great!
/Nicklas
Sent from my Sony Xperia™ smartphone
---- Paul Ramsey wrote ----
>Hey all,
>  I've had a branch running for a while, that Nik has tested a little,
>for tree-based distance calculations. I've been doing some testing on
>it and finding that when it's good, it's very very good (10x
>improvements when dealing with large geometries) and when it's bad,
>it's not so great (3x worse than existing naive distance on
>small-vs-small geometries).
>  All this so far without also reaching into the next obvious
>enhancement, adding a caching behaviour, like the
>point-in-polygon/geos code. That will make everything about 2x faster
>yet, as about 50% of the time seems to be spent in building up trees.
>  I'd like to merge my branch in, along with a temporary testing
>function _ST_DistanceRectTree(geom, geom) so that we can figure out
>how we exactly want to put this code to use. Any objections? If
>nothing else, it will replace the current dead code lying in lwtree.c.
>P.
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at lists.osgeo.org
>https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180220/32d367ae/attachment-0001.html>
