[postgis-devel] Postgis documentation clarification request.
Birkett, Scott
scott.birkett at pioneer.com
Fri Feb 23 10:42:50 PST 2018
Dear postgis developers,
"PostgreSQL 9.5.6 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.3 20140911 (Red Hat 4.8.3-9), 64-bit POSTGIS="2.2.5 r15298" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.0.3, released 2016/07/01" LIBXML="2.9.1" LIBJSON="0. (...)"
Please consider adding documentation to explain why the following SQL statement returns true.
SELECT ( ST_AsTiff(raster, ARRAY[1,2]) = ST_AsTiff(raster, ARRAY[3]) )
FROM
SELECT '0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster
as rast;
The raster created by …
is a two band raster with zeros in the first band and ones in the second band.
( ST_AsTiff(raster, ARRAY[1,2]) = ST_AsTiff(raster, ARRAY[3]) ) appears to evaluate to true because any raster band selection on a band that doesn’t exists (ARRAY[3] in this example) returns ALL the raster bands.
The functionality is especially confusing as some raster functions (ST_SummaryStats, ST_DumpValues, etc.) take the band argument more literally and return nothing when requesting bands that don’t exist.
I am not asking for ST_Band or ST_AsTiff to change functionality, but if the documentation https://postgis.net/docs/RT_ST_AsTIFF.html made it apparent that parameter integer[] nbands fetches you ALL the bands when band request are made that don’t exists might help people of the future.
This communication is for use by the intended recipient and contains information that may be Privileged, confidential or copyrighted under applicable law. If you are not the intended recipient, you are hereby formally notified that any use, copying or distribution of this e-mail,in whole or in part, is strictly prohibited. Please notify the sender by return e-mail and delete this e-mail from your system. Unless explicitly and conspicuously designated as "E-Contract Intended", this e-mail does not constitute a contract offer, a contract amendment, or an acceptance of a contract offer. This e-mail does not constitute a consent to the use of sender's contact information for direct marketing purposes or for transfers of data to third parties. Francais Deutsch Italiano Espanol Portugues Japanese Chinese Korean http://www.DuPont.com/corp/email_disclaimer.html
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180223/defd5096/attachment-0001.html>
