[postgis-devel] Bias in ClusterKmeans
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Jan 4 10:38:01 PST 2018
I fixed the lost clusters issue,
https://trac.osgeo.org/postgis/changeset/16212.
I also made an init algorithm that does it supposedly with less skew.
Patch: https://github.com/postgis/postgis/pull/181
Tom, can you please file a formal ticket to http://trac.osgeo.org/postgis/?
Would you be able to test it on your dataset to see if that solves your
issue?
We would also need a test case to freeze the behavior.
Paul, can you review it please and find a case that may be broken by such
fix? :)
пт, 29 дек. 2017 г. в 14:07, Darafei "Komяpa" Praliaskouski <me at komzpa.net>:
> Here's a test that I'd say our KMeans definitely fails - on a list of 2205
> non-repeating points when asked to find 2205 clusters it only finds 1859,
> so K is not really honored:
> select count(distinct cid) from
> (WITH
> points AS (
> SELECT ST_MakePoint(x,y) geom from generate_series(-10,10) x,
> generate_series(-10,10) y
> union all
> SELECT ST_MakePoint(x+0.1,y) geom from generate_series(-10,10) x,
> union all
> SELECT ST_MakePoint(x+0.2,y) geom from generate_series(-10,10) x,
> union all
> SELECT ST_MakePoint(x,y+0.1) geom from generate_series(-10,10) x,
> union all
> SELECT ST_MakePoint(x,y+0.2) geom from generate_series(-10,10) x,
> SELECT ST_ClusterKMeans(geom,2204) over () AS cid, geom
> FROM points) z;
> пт, 29 дек. 2017 г. в 8:07, Regina Obe <lr at pcorp.us>:
>> While you guys are grokking the code, perhaps you can figure out what is
>> causing this test to fail once in a while.
>> Fails more on 32-bit more than 64-bit. Now I saw a similar failure on
>> travis, might be Darafei's specially added testing sauce triggering that
>> one J
>> https://trac.osgeo.org/postgis/ticket/3700
>> Anyway this failure is not repeatable unfortunately
>> Last one happened just recently on winnie's 64-bit run.
>> https://trac.osgeo.org/postgis/ticket/3700#comment:18
>> Darafei if you want to experiment with logbt as you mentioned in that
>> ticket +1 from me for 2.5 branch. Don't wait for any more +1s, just do and
>> ask for forgiveness later if anyone screams J
>> Thanks,
>> Regina
>> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
>> Behalf Of *Tom van Tilburg
>> *Sent:* Thursday, December 28, 2017 5:21 PM
>> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>> *Subject:* Re: [postgis-devel] Bias in ClusterKmeans
>> I was just looking at that code and trying to wrap my head around the
>> rationale. Why a diagonal seed?
>> A grid would indeed solve my example but I have more irregular input
>> data.
>> Would a quick & dirty solution be to spread K points randomly in the
>> convex-hull of the the input set?
>> Your proposed strategy looks much more stable than the current and as far
>> as I can grasp it would give denser seeding where there is higher density
>> of geometries. I wonder though why it wouldn't be enough to just randomly
>> pick points from the input set, apart from having a different outcome every
>> time.
>> Tom
>> On Thu, Dec 28, 2017 at 10:47 PM, Darafei "Komяpa" Praliaskouski <
>> me at komzpa.net> wrote:
>> Tom, the line of code that does the diagonal seeding is this:
>> https://github.com/postgis/postgis/blob/svn-trunk/liblwgeom/lwkmeans.c#L187
>> At the very least to fix your case it may need to seed in a grid, so you
>> need to make it two loops for row and column and estimate range for them
>> from min/max height and width.
>> postgis-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180104/9a31fd1a/attachment.html>
