[postgis-devel] World Sinusoidal Projection in PostGIS
G. Allegri
giohappy at gmail.com
Fri Jan 5 02:06:16 PST 2018
World sinusoidal is EPSG:54008 so I guess it's proj string [1] is already
inside the spatial_ref_sys table, which is where CRS definitions are
defined in PostGIS.
You can verify it doing:
SELECT * FROM spatial_ref_sys WHERE srid = 54008
Giovanni
[1] http://epsg.io/54008.proj4
Il 5 gen 2018 10:46 AM, "José María" <jmamuedo at gmail.com> ha scritto:
> Hi,
> I spent several days searching info about how to use Worl Sinusoidal
> porjection in PostGIS. But I didn´t find any responses.
> I only found a possible codification (54008) in ESRI, but I don´t know
> how to manage this projection in PostGIS.
> Any people can I help me with this discussion?
> Thanks.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180105/5566695a/attachment.html>
