[postgis-devel] Met Postgres crash while using postgis
benjamin2037 at sina.com
Thu Jul 19 04:17:46 PDT 2018
Hi We use Postgres9.4 and postgis 2.2.2, one of our customer report they met to crash while issue the below query.SELECT guid, ST_X(location :: GEOMETRY) AS lng, ST_Y(location :: GEOMETRY) AS latFROM xxx WHERE city_guid = 'xxx'AND no_use IS NOT TRUE and pending_num >= 0AND _ST_Covers(ST_SetSRID('POLYGON((121.23592586538606 37.5788252744999,121.23592586538606 37.55599397911481,121.25212104314092 37.55599397911481,121.25212104314092 37.5788252744999,121.23592586538606 37.5788252744999))'::TEXT, 4326), location);The create table statement list below:CREATE TABLE t_recycle (guid character varying(36) NOT NULL,xxx_guid character varying(36) NOT NULL,xxx_name character varying(10) NOT NULL,address character varying(100),location geography(Point,4326) NOT NULL,location_hash character varying(32) NOT NULL,t_num integer DEFAULT 0 NOT NULL,x_num integer DEFAULT 0 NOT NULL,create_date timestamp without time zone,update_date timestamp without time zone,remark character varying(100),image_url jsonb,create_user_name character varying(10),create_user_guid character varying(36),update_user_guid character varying(36),update_user_name character varying(10),no_use boolean,mark_type smallint,CONSTRAINT pk_t_recycle PRIMARY KEY (guid)); the stack like this:Loaded symbols for /u01/pgsql_20171103/lib/plpgsql.soCore was generated by `postgres: bike_bos_rw bike_bos 10.81.55.17(42324) SELECT '.Program terminated with signal 11, Segmentation fault.#0 repalloc (pointer=0x34c3b30, size=72) at mcxt.c:745745 mcxt.c: No such file or directory.in mcxt.cMissing separate debuginfos, use: debuginfo-install glibc-2.12-1.166.alios6.7.x86_64 libselinux-2.0.94-5.2.1.alios6.x86_64(gdb) bt#0 repalloc (pointer=0x34c3b30, size=72) at mcxt.c:745#1 0x00002ba42377e561 in wkt_yyensure_buffer_stack () at lwin_wkt_lex.c:1741#2 0x00002ba42377e789 in wkt_yy_switch_to_buffer (new_buffer=0x305c530) at lwin_wkt_lex.c:1521#3 0x00002ba42377e8d1 in wkt_yy_scan_buffer (base=0x305c420 "POLYGON((121.23592586538606 37.5788252744999,121.23592586538606 37.55599397911481,121.25212104314092 37.55599397911481,121.25212104314092 37.5788252744999,121.23592586538606 37.5788252744999))", size=<value optimized out>) at lwin_wkt_lex.c:1784#4 0x00002ba42377e957 in wkt_yy_scan_bytes (yybytes=0x305c310 "POLYGON((121.23592586538606 37.5788252744999,121.23592586538606 37.55599397911481,121.25212104314092 37.55599397911481,121.25212104314092 37.5788252744999,121.23592586538606 37.5788252744999))", _yybytes_len=192) at lwin_wkt_lex.c:1828#5 0x00002ba42377e9d9 in wkt_lexer_init (src=<value optimized out>) at lwin_wkt_lex.l:19#6 0x00002ba42377e0bf in lwgeom_parse_wkt (parser_result=0x7fffa8a26d60,wktstr=0x305c310 "POLYGON((121.23592586538606 37.5788252744999,121.23592586538606 37.55599397911481,121.25212104314092 37.55599397911481,121.25212104314092 37.5788252744999,121.23592586538606 37.5788252744999))", parser_check_flags=7) at lwin_wkt_parse.y:67#7 0x00002ba42373b9ee in LWGEOM_in (fcinfo=0x7fffa8a26de0) at lwgeom_inout.c:122#8 0x00000000007e23ca in DirectFunctionCall1Coll (func=0x2ba42373b930 <LWGEOM_in>, collation=<value optimized out>, arg1=<value optimized out>) at fmgr.c:1062#9 0x00002ba42373aa06 in parse_WKT_lwgeom (fcinfo=0x3231050) at lwgeom_inout.c:716#10 0x00000000005c24cc in ExecMakeFunctionResultNoSets (fcache=0x3230fe0, econtext=<value optimized out>, isNull=0x3230b80 "", isDone=<value optimized out>) at execQual.c:2026#11 ExecEvalFunc (fcache=0x3230fe0, econtext=<value optimized out>, isNull=0x3230b80 "", isDone=<value optimized out>) at execQual.c:2417#12 0x00000000005c245e in ExecMakeFunctionResultNoSets (fcache=0x32307d0, econtext=0x2bf1570, isNull=0x3230370 "", isDone=<value optimized out>) at execQual.c:2000#13 ExecEvalFunc (fcache=0x32307d0, econtext=0x2bf1570, isNull=0x3230370 "", isDone=<value optimized out>) at execQual.c:2417#14 0x00000000005c245e in ExecMakeFunctionResultNoSets (fcache=0x322ffc0, econtext=0x2bf1570, isNull=0x322fb60 "", isDone=<value optimized out>) at execQual.c:2000#15 ExecEvalFunc (fcache=0x322ffc0, econtext=0x2bf1570, isNull=0x322fb60 "", isDone=<value optimized out>) at execQual.c:2417#16 0x00000000005c245e in ExecMakeFunctionResultNoSets (fcache=0x322f7b0, econtext=0x2bf1570, isNull=0x7fffa8a273ff "", isDone=<value optimized out>) at execQual.c:2000#17 ExecEvalFunc (fcache=0x322f7b0, econtext=0x2bf1570, isNull=0x7fffa8a273ff "", isDone=<value optimized out>) at execQual.c:2417#18 0x00000000005bbbce in ExecQual (qual=<value optimized out>, econtext=0x2bf1570, resultForNull=<value optimized out>) at execQual.c:5236#19 0x00000000005c275f in ExecScan (node=0x2bf1600, accessMtd=0x5cb340 <BitmapHeapNext>, recheckMtd=0x5cb2f0 <BitmapHeapRecheck>) at execScan.c:195#20 0x00000000005bb2b8 in ExecProcNode (node=0x2bf1600) at execProcnode.c:414#21 0x00000000005b9475 in ExecutePlan (queryDesc=0x1f18bb8, direction=<value optimized out>, count=0) at execMain.c:1490#22 standard_ExecutorRun (queryDesc=0x1f18bb8, direction=<value optimized out>, count=0) at execMain.c:319#23 0x00002b9fe76a632b in pgss_ExecutorRun (queryDesc=0x1f18bb8, direction=ForwardScanDirection, count=0) at pg_stat_statements.c:871#24 0x00002b9fe7aad635 in explain_ExecutorRun (queryDesc=0x1f18bb8, direction=ForwardScanDirection, count=0) at auto_explain.c:241#25 0x00000000006d5317 in PortalRunSelect (portal=0x106c680, forward=<value optimized out>, count=0, dest=<value optimized out>) at pquery.c:948#26 0x00000000006d5ff8 in PortalRun (portal=0x106c680, count=9223372036854775807, isTopLevel=1 '\001', dest=0x110e510, altdest=0x110e510, completionTag=0x7fffa8a27900 "") at pquery.c:790#27 0x00000000006d2589 in exec_execute_message (portal_name=0x110e100 "", max_rows=9223372036854775807) at postgres.c:2031#28 0x00000000006d43bc in PostgresMain (argc=<value optimized out>, argv=<value optimized out>, dbname=0x103d8f0 "bike_bos", username=<value optimized out>) at postgres.c:4362#29 0x000000000066bd5f in BackendRun (argc=<value optimized out>, argv=<value optimized out>) at postmaster.c:4300#30 BackendStartup (argc=<value optimized out>, argv=<value optimized out>) at postmaster.c:3963#31 ServerLoop (argc=<value optimized out>, argv=<value optimized out>) at postmaster.c:1693#32 PostmasterMain (argc=<value optimized out>, argv=<value optimized out>) at postmaster.c:1301#33 0x00000000005f474c in main (argc=3, argv=0x103c610) at main.c:233(gdb) f 1#1 0x00002ba42377e561 in wkt_yyensure_buffer_stack () at lwin_wkt_lex.c:17411741 lwin_wkt_lex.c: No such file or directory.in lwin_wkt_lex.c(gdb) p yy_buffer_stack$1 = (YY_BUFFER_STATE *) 0x34c3b30(gdb) p *yy_buffer_stack$2 = (YY_BUFFER_STATE) 0x0Since we can not re-produce the dump. Could you help to analyze the root cause? Thank you very much!
Benjamin Xiongfrom Alibaba
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180719/00e28c5c/attachment-0001.html>
