[postgis-devel] [SoC]Week 10 Report - Implement Geospatial Data Viewer in pgAdmin4 for PostGIS
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 27 14:26:40 PDT 2018
Trying out the geoviewer branch,
I can run 'make bundle' fine in the master branch. In your branch it
errors out like this:
ERROR in ./pgadmin/static/jsx/map_view/map_view.jsx
Module not found: Error: Can't resolve 'ol/dist/ol.js' in
'/Users/pramsey/Code/pgadmin4/web/pgadmin/static/jsx/map_view'
@ ./pgadmin/static/jsx/map_view/map_view.jsx 60:9-33
@ ./pgadmin/tools/sqleditor/static/js/sqleditor.js
ERROR in ./pgadmin/static/jsx/map_view/map_view_map.jsx
@ ./pgadmin/static/jsx/map_view/map_view_map.jsx 37:9-33
error Command failed with exit code 2.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about
this command.
I assume there's a small piece of configuration not checked in somewhere?
On Sun, Jul 22, 2018 at 7:00 PM, Xuri Gong <xurigoong at gmail.com> wrote:
> Hi,
> I am Xuri Gong. This is my report for week 10(July 16 - 22).
> What did you get done this period?
> Create visualiser for individual geometry in datagrid. [1]
> Fix image url errors in leaflet. [2]
> This visualiser is independent from the geoviewer and is in the
> geometry_visualiser branch[3]. Here is the screen shot:
> Screenshot 1 [4]
> Screenshot 2 [5]
> What do you plan on doing next week?
> Create test for both geometry_visualiser and geoviewer.
> Check the code style to meet the pgAdmin coding standards[6].
> Are you blocked on anything?
> No, I am not blocked.
> Wiki page: [7]
> Public repository: [8]
> [1]
> https://github.com/Gooong/pgadmin4/commit/d6407baa3a0a96adac169d183bed8bc044dbb8f5
> [2]
> https://github.com/Gooong/pgadmin4/commit/3b160b668c4f9b5867b4b2189714c934a5de85c6
> [3] https://github.com/Gooong/pgadmin4/tree/geometry_visualiser
> [4] https://photos.app.goo.gl/kH58WDbZeKAtRvNi8
> [5] https://photos.app.goo.gl/AnQMZndMQ62HGLmbA
> [6] https://pgadmin.org/docs/pgadmin4/dev/coding_standards.html
> [7]
> https://trac.osgeo.org/postgis/wiki/GeospatialDataViewerInPgAdmin4ForPostGIS
> [8] https://github.com/Gooong/pgadmin4/tree/geoviewer
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
