[postgis-devel] Code formatting digging in
Sandro Santilli
strk at kbt.io
Fri Mar 2 13:05:15 PST 2018
On Fri, Mar 02, 2018 at 10:49:23AM +0000, Darafei "Komяpa" Praliaskouski wrote:
> I volunteer to commit to maintain consistent PostGIS codebase formatting as
> responsibility in project.
> That would save everyone the hassle of thinking about styling, finding
> exact version numbers of software they don't care about, and get no
> frustration of broken CI because of code white space and not logic.
How do you plan to do that ?
I'd like to avoid a change history like:
r2000 Fix bug
r2001 Format
r2002 Add feature
r2003 Format
Avoiding that would imply a pre-commit processing.
> Perfectly consistent formatting just comes as a freebie when you use a
> formatter.
A _consistent_ formatter, that is ...
> The main reason I formatted lwgeom_geos.c file completely was it having
> unmatched indentation levels that are hard to find manually.
Theoretically those should be taken care of by editorconfig, does
your editor support it ? Does it change all lines on exit or just
the ones you tweak ?
--strk;
