[postgis-devel] Aggregate STYPE
Regina Obe
lr at pcorp.us
Mon Mar 5 09:00:45 PST 2018
Paul,
Can you please put in a change notice on all the aggs and functions you changed.
NOTE: that all aggs would need to be dropped and recreated and our updater relies on those comments to know to drop the aggregate since we no longer always drop aggs.
Functions we always replace so not quite as big of a deal to have change notice on that.
Strk,
Correct me if I misspoke.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Monday, March 05, 2018 9:15 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Aggregate STYPE
I've removed pgis_abs in https://trac.osgeo.org/postgis/ticket/4035
On Sat, Mar 3, 2018 at 4:17 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Mar 02, 2018 at 02:52:03PM -0800, Paul Ramsey wrote:
>> Memory test, ancient developers:
>> The CREATE AGGREGATE for ST_Union has
>> stype = pgis_abs
>> The CREATE AGGREGATE for ST_AsMVT has
>> stype = internal
>> Now, pgis_abs is just a stub type, it's not real at all, the
>> input/output functions don't do anything, etc. So, is the retention
>> of that type an echo of an earlier time when it wasn't possible to
>> aggregate with an internal stype, or is there an *extra* reason why
>> we don't just use stype=internal for ST_Union()?
> My guess is we want "internal" nowadays, and "pgis_abs" is a leftover
> from the far past. A quick look reveals that use of "internal" for
> state types was introduced in PostGIS-2.4. PostgreSQL documentation
> talk about an "internal" type even in version 7.3.
> --strk;
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
