[postgis-devel] Aggregate STYPE -C SQL API breakage
Regina Obe lr at pcorp.us
Tue Mar 6 22:42:57 PST 2018
It just occurred to me while I was dreaming of upgrading a 1 TB database, that this will probably break my ability to just swap out old library with new so I don't have to install the newer PostGIS
In my older PostgreSQL.  I'll test live to confirm my suspicion later.
While we are enjoying this exercise, you want start a rehearsal run of maintaining C SQL API versions before we go to 3.0.
That would mean putting back the pgis_abs support functions but stubbing them with an error function.
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Tuesday, March 06, 2018 2:48 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Aggregate STYPE
Actually, I think it's even more awful, all the transfns that have
func(pgis_abs) signatures will still be around, since the upgrade will have not replaced them, but rather supplemented them with
func(internal) variants. So all the old transfns will need to be explicitly dropped. Do we have any example of how the chicken/egg problem of dropping a type is supposed to work?
P
On Tue, Mar 6, 2018 at 11:15 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Mar 05, 2018 at 10:21:14AM -0800, Paul Ramsey wrote:
>> OK, I think I've done all the due-diligence in
>> https://trac.osgeo.org/postgis/ticket/4035
> I think the order of the DROPs you added won't work:
>   -- Old accum aggregate support type, removed in 2.5.0
>   DROP FUNCTION IF EXISTS pgis_abs_in(cstring);
>   DROP FUNCTION IF EXISTS pgis_abs_out(pgis_abs);
>   DROP TYPE IF EXISTS pgis_abs;
> I'd think the first two DROP FUNCTION would raise an exception about
> type pgis_abs requiring them (so can't drop). Did you try the upgrade
> --strk;
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
