[postgis-devel] smoothing function Chaikins algorithm
Regina Obe
lr at pcorp.us
Fri Mar 9 04:25:46 PST 2018
Sure. Something I've always wanted.
As far as the name goes, it would be nice to keep Chaikins in the name, but if you want the name to be searchable by purpose
Perhaps something like ST_ChaikinsSmooth
Thanks,
Regina
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nicklas Avén
Sent: Friday, March 09, 2018 5:03 AM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] smoothing function Chaikins algorithm
Hello
I have implemented chiakins algorithm for smoothing geometries.
http://idav.ucdavis.edu/education/CAGDNotes/Chaikins-Algorithm/Chaikins
-Algorithm.html
The algorithm is amazing simple
Signature is:
st_chaikins(geom geometry, n_iterations int, preserve_endpoints
boolean)
Do we want it in PostGIS?
Should it be a more describing name than st_chaikins?
The function more or less doubles the number of vertex points per iteration, so I have to put in a max number of iterations. I tried it with 40 iterations without thinking about it and it of course crashed the server :-)
It can be combined with some simplify function to again reduce number of verteces.
The use case here is geometries generated from raster to smooth out the pixels.
I have some cleanup to do before putting it somewhere.
Thanks
Nicklas
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
