[postgis-devel] Bit setting to compress PostGIS geometries
Björn Harrtell
bjorn.harrtell at gmail.com
Fri Mar 16 14:48:11 PDT 2018
Had to slightly modify to make it work and I'm not sure why you want to go
into negative digit precision.
SQL:
WITH test AS (SELECT 'POINT (123.456789123456 123.456789123456)'::geometry
AS geom)
SELECT
digits,
encode(ST_QuantizeGeometry(geom, ARRAY[digits, digits, digits]), 'hex'),
ST_AsText(ST_QuantizeGeometry(geom, ARRAY[digits, digits, digits]))
FROM test, generate_series(15, -15, -1) AS digits;
Result:
15 01010000005c9a72083cdd5e405c9a72083cdd5e40 POINT(123.456789123456
123.456789123456)
14 0101000000409a72083cdd5e40409a72083cdd5e40 POINT(123.456789123456
123.456789123456)
13 0101000000009a72083cdd5e40009a72083cdd5e40 POINT(123.456789123455
123.456789123455)
12 0101000000009072083cdd5e40009072083cdd5e40 POINT(123.456789123418
123.456789123418)
11 0101000000008072083cdd5e40008072083cdd5e40 POINT(123.45678912336
123.45678912336)
10 0101000000000070083cdd5e40000070083cdd5e40 POINT(123.456789121032
123.456789121032)
9 0101000000000040083cdd5e40000040083cdd5e40 POINT(123.456789076328
123.456789076328)
8 0101000000000000083cdd5e40000000083cdd5e40 POINT(123.456789016724
123.456789016724)
7 0101000000000000003cdd5e40000000003cdd5e40 POINT(123.456787109375
123.456787109375)
6 0101000000000000003cdd5e40000000003cdd5e40 POINT(123.456787109375
123.456787109375)
5 01010000000000000038dd5e400000000038dd5e40 POINT(123.45654296875
123.45654296875)
4 01010000000000000000dd5e400000000000dd5e40 POINT(123.453125 123.453125)
3 01010000000000000000dc5e400000000000dc5e40 POINT(123.4375 123.4375)
2 01010000000000000000c05e400000000000c05e40 POINT(123 123)
1 01010000000000000000005e400000000000005e40 POINT(120 120)
0 010100000000000000000050400000000000005040 POINT(64 64)
-1 010100000000000000000000400000000000000040 POINT(2 2)
-2 010100000000000000000000400000000000000040 POINT(2 2)
-3 010100000000000000000000400000000000000040 POINT(2 2)
-4 010100000000000000000000000000000000000000 POINT(0 0)
-5 010100000000000000000000000000000000000000 POINT(0 0)
-6 010100000000000000000000000000000000000000 POINT(0 0)
-7 010100000000000000000000000000000000000000 POINT(0 0)
-8 010100000000000000000000000000000000000000 POINT(0 0)
-9 010100000000000000000000000000000000000000 POINT(0 0)
-10 010100000000000000000000000000000000000000 POINT(0 0)
-11 010100000000000000000000000000000000000000 POINT(0 0)
-12 010100000000000000000000000000000000000000 POINT(0 0)
-13 010100000000000000000000000000000000000000 POINT(0 0)
-14 010100000000000000000000000000000000000000 POINT(0 0)
-15 010100000000000000000000000000000000000000 POINT(0 0)
/Björn
2018-03-15 20:37 GMT+01:00 Daniel Baston <dbaston at gmail.com>:
> Hi Björn,
> I haven't fully gone through the implementation (seems impressive,
> though!). If you run a query like the one in the docs (copied below) do you
> see a similar amount of trimming?
> AS geom)
> SELECT
> digits,
> encode(ST_QuantizeCoordinates(geom, digits), 'hex'),
> ST_AsText(ST_QuantizeCoordinates(geom, digits))
> Dan
> On Thu, Mar 15, 2018 at 3:22 PM, Björn Harrtell <bjorn.harrtell at gmail.com>
> wrote:
>> Apart from a bug with polygons that have more than one ring I think my
>> implementation does what it should but I'm seeing *very* limited space
>> reductions when going from 15 digits to 6. Any ideas why?
>> 2018-03-14 9:05 GMT+01:00 Björn Harrtell <bjorn.harrtell at gmail.com>:
>>> Ok so I said why not implement using SQL (i.e PL/pgSQL) and I could not
>>> let it go even though it's clearly not a sane way of doing it.
>>> Note that second parameter is an array to be able to set the precision
>>> per ordinal. Here's the implementation for your pleasure:
>>> --example use
>>> select ST_AsText(ST_QuantizeGeometry(st_geomfromtext('POINT(123.12345
>>> 123.12345)'), ARRAY[5,5]));
>>> select ST_AsText(ST_QuantizeGeometry(st_geomfromtext('POINTZ(123.12345
>>> 123.12345 9.9999)'), ARRAY[3,3,1]));
>>> select ST_AsText(ST_QuantizeGeometry(st_geomfromtext('LINESTRING(123.12345
>>> 223.12345, 334.12345 434.12345, 999.999 999.999)'), ARRAY[1,1]));
>>> select ST_AsText(ST_QuantizeGeometry(st_geomfromtext('POLYGON((1 1,
>>> 2.555 2.555, 3 3, 1 1))'), ARRAY[1,3]));
>>> --drop type _quantize_geometry_context cascade;
>>> create type _quantize_geometry_context as (
>>> buffer bytea,
>>> endianness bool,
>>> off integer,
>>> masks bit(64)[],
>>> num_ordinals integer
>>> --drop function _quantize_geometry_coord(c _quantize_geometry_context);
>>> create or replace function _quantize_geometry_coord(c
>>> _quantize_geometry_context) returns _quantize_geometry_context as
>>> declare
>>> masked_byte int;
>>> begin
>>> for o in 1 .. c.num_ordinals loop
>>> for i in 0 .. 7 loop
>>> masked_byte = get_byte(c.buffer, c.off) & substring(c.masks[o] from (i *
>>> 8) + 1 for 8)::int;
>>> c.buffer = set_byte(c.buffer, c.off, masked_byte);
>>> c.off = c.off + 1;
>>> end loop;
>>> end loop;
>>> return c;
>>> end;
>>> language plpgsql;
>>> --drop function _quantize_geometry_coords(c _quantize_geometry_context);
>>> create or replace function _quantize_geometry_coords(c
>>> declare
>>> num_coords int;
>>> begin
>>> num_coords = get_byte(c.buffer, c.off + 3);
>>> c.off = c.off + 4;
>>> for i in 0 .. num_coords - 1 loop
>>> c = _quantize_geometry_coord(c);
>>> end loop;
>>> return c;
>>> end;
>>> language plpgsql;
>>> --drop function ST_QuantizeGeometry(geom geometry, digits_precision
>>> integer[]);
>>> create or replace function ST_QuantizeGeometry(geom geometry,
>>> digits_precision integer[]) returns geometry as
>>> declare
>>> c _quantize_geometry_context;
>>> geomtype integer;
>>> bits_to_keep integer;
>>> ordinalstype integer;
>>> num_rings integer;
>>> num_objects integer;
>>> begin
>>> c.buffer = st_asbinary(geom, 'XDR');
>>> -- TODO: parse geometry type from wkb
>>> geomtype = st_dimension(geom)+1;
>>> -- TODO: parse number of ordinals from wkb
>>> c.num_ordinals = st_ndims(geom);
>>> for i in 1 .. c.num_ordinals loop
>>> bits_to_keep = ceil(digits_precision[i] / log(10, 2));
>>> c.masks[i] = B'1111111111111111111111111111
>>> 111111111111111111111111111111111111' << (52 - bits_to_keep);
>>> end loop;
>>> c.off = 5;
>>> if geomtype = 1 then
>>> elsif geomtype = 2 then
>>> c = _quantize_geometry_coords(c);
>>> elsif geomtype = 3 then
>>> num_rings = get_byte(c.buffer, c.off + 3);
>>> c.off = c.off + 4;
>>> for i in 0..num_rings-1 loop
>>> end loop;
>>> else
>>> raise 'Unsupported geometry type';
>>> end if;
>>> return st_geomfromwkb(c.buffer);
>>> end;
>>> language plpgsql;
>>> /Björn
>>> 2018-03-08 20:52 GMT+01:00 Regina Obe <lr at pcorp.us>:
>>>> I think the extra word is superfluous and hurts my fingers to type.
>>>> Bur Dan likes it and he's the author so oh well.
>>>> -----Original Message-----
>>>> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
>>>> Behalf Of Paul Ramsey
>>>> Sent: Thursday, March 08, 2018 9:25 AM
>>>> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
>>>> Subject: Re: [postgis-devel] Bit setting to compress PostGIS geometries
>>>> ST_QuantizeCoordinates()? or is the extra word superfluous?
>>>> On Thu, Mar 8, 2018 at 6:21 AM, Daniel Baston <dbaston at gmail.com>
>>>> wrote:
>>>> > My understanding is that it should work on big-endian architectures,
>>>> > but I haven't tested it. Maybe Sandro will set up a new bot using QEMU
>>>> > ST_Quantize, then? Or postgis_quantize_geometry?
>>>> > Dan
>>>> > _______________________________________________
>>>> > postgis-devel mailing list
>>>> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180316/8c848a66/attachment-0001.html>
