[postgis-devel] performance test suite
Darafei "Komяpa" Praliaskouski me at komzpa.net
Wed May 2 00:21:52 PDT 2018
I think the biggest part of it is about collecting real world datasets and
workloads.
I was thinking about making a system that would serve as error handler for
things like unexpected GEOS errors that would send offending geometries and
all versions of all software to some (separate) issue tracker.
A lot of software asks "do you want to share usage statistics with us?" -
can we do something similar? If enabled, log number of invocations and
typical characteristics of calls (number of points in geometries, their
types, K for KMeans, whatever seems reasonable for the case) and send
somewhere we can pick it up once a day?
ср, 2 мая 2018 г. в 10:08, Regina Obe <lr at pcorp.us>:
> That sounds like a good start, we could also have a folder on postgis.net
> hosting some data files we can use.
> I was wondering if pg_bench would be of any value.  I honestly haven't
> explored it to know how much flexibility we have in feeding it custom
> queries.  It seems it's possible.
> https://www.postgresql.org/docs/10/static/pgbench.html
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Daniel Baston
> *Sent:* Tuesday, May 01, 2018 4:53 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] performance test suite
> I agree that this would be very useful, not only for catching regressions
> but also to help us promote the performance improvements make it in to each
> release. We itemize performance improvements in the changelog, but we don't
> generally quantify what they mean for typical use cases. It would be nice
> to say by upgrading to release 2.5, typical point-in-polygon queries are
> improved by 20%, K-means is improved by X%, etc.
> To keep the perl/python to a minimum, could we rely on pg_stat_statements
> to do the bulk of the work for us? So it be something as simple as:
> 1) a script that loads or generates test data
> 2) a SQL file that runs a bunch of queries capturing typical usages of
> PostGIS
> 3) something that parses the output of pg_stat_statements
> Dan
> On Tue, May 1, 2018 at 4:42 PM, Regina Obe <lr at pcorp.us> wrote:
> Bjorn,
> Oh you are a man after my own heart.  Yes definitely.  Performance testing
> is a very weak spot in our testing.  I hate finding out about this when
> users complain J
> I think starting it off as a separate project is a good idea but I'd
> really love to see it eventually as part of PostGIS core that say we can
> flip on and have enabled for some bots or when we are about to release.
> How we keep record of timings etc, seems to me a bot end thing the testing
> bot reporting to some mothership database.
> As to whether it should be done in perl or something else – to be honest
> Perl scares the shit out of me.  Python sadly I haven't warmed up to
> either.  I always feel like I'm fumbling thru a mine field with both.  Okay
> that's an exaggeration.
> But then again Perl is a dependency we are used to having, so whatever you
> do ideally shouldn't add any crazy dependencies and if additional
> dependencies – a dependency that can run on all platforms.  It's okay to
> have extra dependencies as long as they are not required for regular
> testing.  I think Komzpa already put in some logic for code coverage
> testing via lcov for example, which is fine since it's not a requirement.
> Thanks,
> Regina
> Behalf Of *Paul Ramsey
> *Sent:* Tuesday, May 01, 2018 1:08 PM
> *To:* Björn Harrtell <bjorn at wololo.org>; PostGIS Development Discussion <
> I think perhaps “do it as a separate project”. It’s going to be complex,
> it’s going to be brittle, it’s going to eventually break and I’d rather not
> have it sitting around broken inside the main source tree. The only way to
> find the regressions is going to be longitudinally testing and keeping
> track of numbers over time, so it’ll be quite a complex piece of work.
> P
> On May 1, 2018, at 10:05 AM, Björn Harrtell <bjorn.harrtell at gmail.com>
> wrote:
> Hi devs,
> In recent times I've been pondering on about how to make a sensible test
> suite specifically for performance. Hacking/extending run_test.pl to
> accommodate for this has been the only suggested path forward but to me
> it's a dead end mostly because of perl (sorry)-
> The reason why this has become a to me apparent missing thing is due to:
> 1. My own work on https://trac.osgeo.org/postgis/ticket/4076.
> 2. The recently discovered large performance regression of ST_Union
> tracked by https://trac.osgeo.org/postgis/ticket/4075. Even if it's in
> GEOS and could perhaps be performance tested there, I think it would not be
> wrong to also performance test ST_Union without consideration of underlying
> implementation.
> Any additional thoughts on the subject? do it in perl or don't do it? :)
> Regards,
> /Björn
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20180502/d07afd73/attachment.html>
