[postgis-devel] [postgis-users] PostGIS 2.5.0 alpha released
Regina Obe lr at pcorp.us
Wed May 30 11:05:21 PDT 2018
Hmm I've been seeing errors too (haven't checked if they match yours) but
chucked it up to an upgrade in ImageMagick on debbie and that we need to
revise our image magick rendering script.
When I looked at the generated html and pdfs, they didn't seem to be
affected by these errors so I kinda ignored them since more pressing things
to attend to.
Did the images build okay for you e.g. the images/de9im02.png ?
The image magick routine builds the images from .wkt files (that contain
lines of well-known geometries ) using our liblwgeom lib.
The generator was last changed Jan 2018 and the change was not backported to
2.4, so I guess that might have caused this issue.
https://trac.osgeo.org/postgis/changeset/16296
I have ticketed at https://trac.osgeo.org/postgis/ticket/4098
Thanks for the report,
Regina
-----Original Message-----
Sent: Wednesday, May 30, 2018 1:31 PM
To: Regina Obe <lr at pcorp.us>
Cc: 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-users] PostGIS 2.5.0 alpha released
  The PostGIS development team is pleased to release PostGIS 2.5.0alpha.
I have done a local update of the pkgsrc entry form 2.4.4 to 2.50alpha.
When buiding, I get a vast number of errors from convert, that I have
never seen before (and certainly are not in 2.4.4).   It sort of looks
like one of the files is corrupted, but I'm wildly guessing.
  generating ../images/de9im02.png
  convert: non-conforming drawing primitive definition `+' @
error/draw.c/DrawImage/3205.
  convert: non-conforming drawing primitive definition `circle' @
error/draw.c/DrawImage/3605.
  Failure return code (1) from command: convert -size 200x200 xc:none -fill
DarkSeaGreen4 -strokewidth 0 -draw "circle 25,51 25, +\260\367^?^?'" -flip
tmp1.pngconve\
"#00bfff" -strokewidth 0 -draw "circle 75,106 75, +\260\367^?^?'" -flip
tmp2.pnggenerati\
  ng ../images/st_azimuth01.png
  convert: non-conforming drawing primitive definition `P\261\260\367^?^?''
@ error/draw.c/DrawImage/3205.
