[postgis-devel] r17001 broke upgrades
Sandro Santilli
strk at kbt.io
Mon Nov 12 12:18:54 PST 2018
r17001 broke upgrades from 2.1, please see
https://drone.osgeo.org/postgis/postgis/1506
The error is:
Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION '2.1.9'
Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE TO '3.0.0dev'
Died at ../run_test.pl line 1479.
failed (Error encountered altering EXTENSION POSTGIS: /tmp/pgis_reg/regress_log)
createlang: language "plpgsql" is already installed in database "postgis_reg"
CREATE EXTENSION
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade(); to finish the
upgrade. After upgrading, if you want to drop raster, run: DROP EXTENSION postgis_raster;
ERROR: operator argument types must be specified in ALTER OPERATOR FAMILY
CONTEXT: SQL statement "
ALTER OPERATOR FAMILY gist_geometry_ops_nd USING gist
ADD OPERATOR 6 ~~= ;
PL/pgSQL function inline_code_block line 26 at EXECUTE
The commit log references a GitHub pull request:
https://github.com/postgis/postgis/pull/327
The Pull request does NOT reference a Trac ticket so I don't know
where else to report this issue.
Any committers please keep an eye on all bots. Travis alone does not
test all we want to test. Dronie is a great tester for upgrades...
--strk;
