[postgis-devel] Validity flag
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Nov 15 02:01:57 PST 2018
> We have had lots of discussions internally about whether validity is
> linked or not to the handling of precision (i.e. coordinates snapped to
> a regular grid rather than using the floating point irregular grid). We
> finally conclude discussions about handling of precision should be
> postponed and we should focus first on validity (even if we already have
> some ideas about a ST_Valid variant that takes a precision as arguments).
Is there any spec that defines "Valid within precision"?
We then propose to add a new bit in the header to handle the validity state.
> Two states Valid/Unknown should be ok, meaning that geometries that have
> already been tested as valid do not have to be tested again, and invalid
> and unknown geometries are treated the same way.
> We could add another bit to deal with a three-state:
> Valid/Invalid/Unknown, but I am not totally sure it is needed.
Bit number two (depending on side you count) in gserialized is already
called Validity:
https://github.com/postgis/postgis/blob/d1e5a63aac0078b6699702d8758dc1f0c7714841/liblwgeom/g_serialized.txt#L45
> There was previously the question of whether to have a validity state by
> geometry backend, since backends may answer differently about validity.
> But it appears differences are due to one of the backends that may have
> a buggy implementation of the validity check for some cases.
> For example, PolygonZ with random coordinates on Z are valid for GEOS,
> and should not be.
> In theory, on very extreme cases at the limit of floating point
> representation, GEOS and SFCGAL may have predicates that answer
> differently, but in practice, despite our efforts, we are not able to
> exhibit such cases.
Do we need ST_IsValid to actually call both implementations and store AND
of them in Validity bit? Can we also print the mismatch warning then?
> So we would prefer to have only one definition of validity for everyone
> and fix validity test bugs of one or the other backend.
> The validity state could also be enforced by adding a type modifier,
> like Geometry(point, 4326, valid). We do not have a strong opinion about
> that, any pro/cons ?
No pro that I see. You can't enforce typmod on function signature, so it's
not that useful - you can't define a function that will only operate on
valid inputs.
> We propose to add/modify the following functions:
> - ST_IsValid:
> - if the geometry has a validity flag set to Valid, do not do anything
> - otherwise, test if the geometry is valid.
> - ST_Validate(geom) : calls ST_IsValid and sets the validity flag if it
> is Valid
> - ST_HasValidityFlag(geom)
> - ST_ForceValidityFlag(geom, is_valid), force the validity flag. To be
> used with caution.
Did you say that invalid in SFCGAL can crash backend? Well, that's a way to
DoS a database, so better not be implemented.
I have a feeling it's a job for something like VACUUM, to walk the tables
and validate geometries in background.
> Then what to do with this validity flag in other functions ?
> When geometries are passed as input, the main goal is to shortcut some
> verification code when the geometry is known to be valid. The initial
> target was to speed up SFCGAL functions, and we would already benefit
> from it, but it could be used elsewhere.
> For functions that output geometries, for creation or modification, the
> question is whether to set or maintain a validity flag, without a call
> to a full validity check. Since it is probably hard to ensure every
> modification functions maintain the flag, we propose in a first step to
> reset the validity flag for every function that returns a geometry
> (except for some possible trivial cases). This won't add any regression
> and would let time to optimize functions' output step by step.
> Looking forward to read your reactions :)
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181115/b5fe0078/attachment-0001.html>
