[postgis-devel] Error creating postgis extension
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Nov 29 02:21:02 PST 2018
Our sysadmin was just deploying a RHEL 7.5 for new project and complained
that PGDG's RPMs are built in super weird way depending on both Proj 4.8
and Proj 4.9, and he's unable to deploy environment for us quickly.
It looks like your failure can have the same roots.
I ticketed it under https://redmine.postgresql.org/issues/3784. I am no RPM
expert but it may happen you need to build RPMs on a clean machine without
proj 4.8 as a workaround.
On Thu, Oct 25, 2018 at 2:43 PM Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> CentOS 7-latest, GeOS 3.7.0, PostGIS 2.5.0. Getting this error:
> postgres=# create extension postgis;
> ERROR: could not load library "/usr/pgsql-11/lib/postgis-2.5.so":
> /usr/pgsql-
> 11/lib/postgis-2.5.so: undefined symbol: geod_polygon_init
> I can see the function in PostGIS code, but no idea why it is failing.
> Any ideas?
> Regards,
> Devrim Gündüz
> EnterpriseDB: https://www.enterprisedb.com
> PostgreSQL Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181129/98065807/attachment.html>
