[postgis-devel] Getting PostGIS 3.0alpha1 super early
Greg Troxel gdt at lexort.com
Fri Nov 30 08:18:41 PST 2018
"Regina Obe" <lr at pcorp.us> writes:
> [timeline question about 3}
> I think once we have done the remove header install (and make all liblwgeom
> static (if we agree to that) )
> Only 4 more changes:
> 1) break postgis_sfcgal out into its own .so, note it was already a separate
> extension, so this is more a packaging change than a user facing change
> 2) remove header install (and possibly remove liblwgeom install as a
> library)
> 3) Paul can comment on this -- I think we were going to change the postgis
> geometry structure a bit to perhaps have some extra bits and allow for
> different storage types.
> I haven't been paying attention if that is done or just experimental on his
> fork.
> 4) We may drop support for GEOS 3.5
The first two are significant for packaging.  (encoding that geos 3.6 is
needed is easy, and even that is old now)
> Big things we've already got that aren't going to change before release
> 1) postgis_raster is NOW a separate extension (it was always a separate lib
> file) so this is big user facing change
> 2) Getting rid of the minor version on the lib file - so now it's just
> postgis-3, rtpostgis-3, postgis_sfcgal-3, postgis_topology-3
> And will be this way from PostGIS 3.0 thru PostGIS 3.last-minor-version
> 3) Dropped support for PostgreSQL 9.4 (9.5+ is only ones supported) - still
> need to update the docs to reflect this
Thanks for the summary.
> So alpha I'd like to get the first 3 out of the way and Ideally the decision
> on GEOS also.
Agreed that an alpha before those things happen is premature.
> It won't be a feature freeze for functions, we'll still be adding in new
> functions, but those won't change packaging or upgrade process.
