[postgis-devel] Faster ST_Intersection
Martin Davis
mtnclimb at gmail.com
Tue Oct 23 10:50:19 PDT 2018
And found:
https://pdfs.semanticscholar.org/666f/663a16b0948aaf27a3b26d65fa8f644f70f1.pdf
On Tue, Oct 23, 2018 at 10:35 AM Martin Davis <mtnclimb at gmail.com> wrote:
> W. R. Franklin was one of the early researchers into polygon overlay, and
> he published a paper "Calculating the Area of Overlaid Polygons Without
> Constructing the Overlay" back in 1994 [1]. Unfortunately behind a paywall,
> but maybe further sleuthing will uncover it in a dusty corner of the net.
> It's not obvious to me that his algorithm could have a lower computational
> complexity, but the constant factor might be lower. And possibly there's a
> robustness advantage too.
> [1]
> https://www.researchgate.net/publication/2804714_Calculating_the_Area_of_Overlaid_Polygons_Without_Constructing_the_Overlay
> On Tue, Oct 23, 2018 at 10:04 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> The first GIS system I ever used had an “intersection area” function that
>> was distinct from, and faster than, the full-on “intersection” function
>> that output a new geometry. I wonder if there is some possibility there…
>> P
>> On Oct 23, 2018, at 6:01 PM, Darafei Komяpa Praliaskouski <me at komzpa.net>
>> wrote:
>> Hi,
>> I have two polygonal layers to intersect and need to measure area of
>> intersections.
>> ST_Area(ST_Intersection(a.geom, b.geom)) works fine, but is rather slow.
>> Typical polygon on first side has <10 edges, on second 200..1000 edges.
>> What are my options to make it faster? Any ideas, links, experiences to
>> share are welcome.
>> For starters, this seems to work faster than vanilla ST_Intersection in
>> my case:
>> create or replace function clipped_st_intersection(geom1 geometry, geom2 geometry)
>> returns geometry
>> as $$select ST_Intersection(
>> case
>> when ST_MemSize(geom1) > 160 then ST_ClipByBox2D(geom1, geom2)
>> else geom1 end, case
>> when ST_MemSize(geom2) > 160 then ST_ClipByBox2D(geom2, geom1)
>> else geom2 end)$$
>> language sql
>> immutable
>> strict
>> parallel safe;
>> Darafei Praliaskouski
>> Support me: http://patreon.com/komzpa
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181023/d37e0a27/attachment.html>
