[postgis-devel] Faster ST_Intersection
Daniel Baston
dbaston at gmail.com
Tue Oct 23 12:39:51 PDT 2018
Another route that sacrifices accuracy (that the isochrones probably
don't have in the first place) would be to rasterize the isochrones
into a travel-time raster and then perform zonal statistics with the
buildings.
Dan
On Tue, Oct 23, 2018 at 3:06 PM Darafei "Komяpa" Praliaskouski
<me at komzpa.net> wrote:
> Martin,
> The case for intersections only is the same as 25 years ago: interactively summarize demographics by some area.
> In my benchmarking case I have 33575 buildings with population in metadata and 233597 points in them on one side, and one minute walking isochrones for three hours subdivided into 14642 parts with 5315008 points. I want to have the population proportionally summarized for each walking minute. No spatial viz needed in that case, just numbers.
> Raw sum(ST_Area(geom)) for both layers returns in below 100ms. Something like 500ms for all the operation would be interactive enough. Today I went from 280s to 17s on 8-thread i5.
> If you want to play with the data, here it is temporarily:
> https://www.dropbox.com/s/ixg0ap8m8vpzzux/hackerspace_eta.sqld.gz?dl=0 (614mb)
> (all OdBL / from OpenStreetMap, isochrones lead to two spots where Minsk Hackerspace resides).
> Other things I've found today, god bless sci-hub:
> http://sci-hub.tw/https://ieeexplore.ieee.org/document/5380680
> monotone-chain polygon intersection algorithm from 2009.
> Also, here: http://codeforces.com/blog/entry/2514 ("Darts") they manage to calculate area of union without rebuilding the linework, interesting if it can be adapted to intersection with just one sort of edges.
> вт, 23 окт. 2018 г. в 21:24, Martin Davis <mtnclimb at gmail.com>:
>> Darafei, what is your use case for needing intersection areas only?
>> It seems like this should be a common use case in spatial analysis - as long as no spatial visualization of the results are required. (And if they are, perhaps simply computing an interior point for each resultant would suffice for visualization purposes? Which should also be amenable to a faster algorithm - perhaps called InteriorPointClipped)
>> On Tue, Oct 23, 2018 at 10:02 AM Darafei "Komяpa" Praliaskouski <me at komzpa.net> wrote:
>>> Hi,
>>> I have two polygonal layers to intersect and need to measure area of intersections.
>>> ST_Area(ST_Intersection(a.geom, b.geom)) works fine, but is rather slow. Typical polygon on first side has <10 edges, on second 200..1000 edges.
>>> What are my options to make it faster? Any ideas, links, experiences to share are welcome.
>>> For starters, this seems to work faster than vanilla ST_Intersection in my case:
>>> create or replace function clipped_st_intersection(geom1 geometry, geom2 geometry)
>>> returns geometry
>>> as $$select ST_Intersection(
>>> case
>>> when ST_MemSize(geom1) > 160 then ST_ClipByBox2D(geom1, geom2)
>>> else geom1 end, case
>>> when ST_MemSize(geom2) > 160 then ST_ClipByBox2D(geom2, geom1)
>>> else geom2 end)$$
>>> language sql
>>> immutable
>>> strict
>>> parallel safe;
>>> Darafei Praliaskouski
>>> Support me: http://patreon.com/komzpa
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
