[postgis-devel] Faster ST_Intersection
Regina Obe lr at pcorp.us
Fri Oct 26 09:48:29 PDT 2018
We've discussed this before I've especially wanted a BOX 3D geometry primitive as that's a very big thing in 3D augmented reality
I think all the 3D toolkits (I know X3Dom has it, I believe three js has it too).
I think we tried to get at least the concept of a true BOX type in 2.0 and we got into arguments about moving forward on it.
Only one I can think of is SQL/MM specs don't support the thing so we'd be deviating from the specs.
I forget what other arguments were against it.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Friday, October 26, 2018 9:09 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Faster ST_Intersection
It looks like for polygon / box intersection area can be calculated in O(n), by just clamping the ordinates (https://github.com/postgis/postgis/commit/3233ccd19cdb6958b53164262cd812d3f6d70fb2).
It also may be adapted for any convex polygons, with O(n*m) though. Convex check also seems to be O(n). Building dataset tends to be mostly convex (and mostly 4-corner), so this may be a specialized fast path.
Is there a chance we may want BOX() as new geometry primitive to save a is_convex / is_box check? :)
Any other thoughts?
On Tue, Oct 23, 2018 at 8:04 PM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> > wrote:
The first GIS system I ever used had an “intersection area” function that was distinct from, and faster than, the full-on “intersection” function that output a new geometry. I wonder if there is some possibility there…
P
On Oct 23, 2018, at 6:01 PM, Darafei Komяpa Praliaskouski <me at komzpa.net <mailto:me at komzpa.net> > wrote:
I have two polygonal layers to intersect and need to measure area of intersections.
ST_Area(ST_Intersection(a.geom, b.geom)) works fine, but is rather slow. Typical polygon on first side has <10 edges, on second 200..1000 edges.
What are my options to make it faster? Any ideas, links, experiences to share are welcome.
For starters, this seems to work faster than vanilla ST_Intersection in my case:
create or replace function clipped_st_intersection(geom1 geometry, geom2 geometry)
  returns geometry
as $$select ST_Intersection(
              case
                when ST_MemSize(geom1) > 160 then ST_ClipByBox2D(geom1, geom2)
                else geom1 end, case
                when ST_MemSize(geom2) > 160 then ST_ClipByBox2D(geom2, geom1)
                else geom2 end)$$
language sql
immutable
strict
parallel safe;
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181026/a48510e0/attachment.html>
