[postgis-devel] [postgis-users] PostGIS case usages
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Fri Oct 26 12:53:36 PDT 2018
Some things I've been using PostGIS for:
- render OpenStreetMap. That's how I got to know about PostGIS, osm2pgsql,
mapnik and its styles. Changing order of things, removing clutter of icons
from map, adding clutter of icons you need for this map, getting tile
server online. Sorting by area to get smaller polys on top of bigger.
ST_PointOnSurface for better icon placement. ST_Linemerge for rendering
street labels on lower zooms, when street segments are too small. Rotating
house number labels to be parallel to streets. Extruding houses and making
a layer of shadows for them.
- extracting some type of data from OpenStreetMap. First osm2pgsql, then
debug a WHERE clause in QGIS (in right-click - Filter on layer), then get
it out as ST_AsGeoJSON, then publish on geojson.io.
- binning some data. Get some lon, lat, value data, group by
ST_Expand(ST_SnapToGrid(geom)), show in QGIS, add transparency to layer,
colorize by Graduated in Quantile mode. Look, get insights.
- stealing some data from some web endpoint. Make python func that gets
data from some endpoint (for example, OSRM to get a route and travel time
from A to B, or google geocoder for some text addresses), store and
aggregate that.
- filling tax forms: get taxi trips, calculate start/end boroughs
(point-in-poly), check they had toll booth on the way (ST_DWithin), check
length (a call to OSRM to snap to roads + ST_Length), check if customer got
where they planned to go (ST_Distance / ST_LineLocatePoint).
- calculating population by some polygons ("zonal statistics"), example
"where should I open cafe in Minsk" is
https://github.com/Komzpa/minsk-population.
- wifi positioning: given this list of wifi mac addresses device sees and
last known gps position, and a history of such data for all users, what is
more likely position this user is at? (ST_GeometricMedian, weights).
- generating game map admin boundaries. ST_VoronoiPolygons(settlements),
ST_Intersection(voronoi, land), ST_ClusterKMeans(voronoi, num_players),
ST_Union() group by cid.
пт, 26 окт. 2018 г. в 20:05, Regina Obe <lr at pcorp.us>:
> Hey all. So we've been in talks with our editor about having a 3rd Edition
> of PostGIS hopefully to be released around the same time as PostGIS 3.0.
> I think they are more or less sold on the idea except they did ask about
> current market share and usage.
> Part of the reason for that is our previous editions focused a lot on "How
> do I use this function or do this weird sounding thing that only GIS people
> can make sense of" instead of "How do I do this real world thing"
> So one of the thoughts was having our table of contents be more like "How
> do
> I do this with PostGIS" in somewhat laymen terms that most people can
> relate
> to - like Political Districting, Real Estate analysis (walk scores,
> elevation measurements to determine viablility of building on a plot of
> land)
> without scaring people off with "real world things" they can't relate to
> or
> in overly techy terms.
> Also since the 2nd Edition (which was in 2015 super ancient now since the
> New shiny version at the time was 2.1 and 2.1 is not even supported
> anymore).
> Other major thing changed is a lot of people are deploying PostGIS on cloud
> offerings like Amazon RDS, Microsoft Azure, and Google PostgreSQL for Cloud
> so we plan to cover a bit about some things relevant in those that may not
> be relevant when deploying on your own server.
> That said, if people can respond with what things they are currently using
> PostGIS for and also what hosting they are using for PostGIS, that would be
> helpful for us to get a better idea of focus points.
> It'd be great if you posted on the list, but if you are shy or need your
> usage anonymized, you can write directly to me.
> Thanks,
> Regina
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20181026/465bf1cc/attachment.html>
