[postgis-devel] [postgis-users] PostGIS case usages
Nicklas Avén
nicklas.aven at jordogskog.no
Tue Oct 30 00:34:25 PDT 2018
Hi Regina
Very good news with a new PostGIS book!
A simple but very powerful combination of tools I use quite a lot is
PostgreSQL/PostGIS and postgREST (http://postgrest.org)
PostgREST uses postgreSQL built in json functions to create a rest-api.
It can serve tables and views out of the box, but also functions (to
build customized json objects).
So it is fairly straight forward to create a simple geojson service
with bounding box filtering. It also has an authentication system where
the db-role to use is baked into a jwt.io token that goes in the
request header. So, with some row level security out of the box or
customized row level security, the geometries delivered can be
controlled by the token used.
With all the functionality in PostgreSQL and PostGIS straight into the
api controlled by ordinary database roles this is very powerful.
I use nginx in front but postgrest can also run it's own web server.
I think this could be worth some text in a nnew book :-)
Regards
Nicklas
On Fri, 2018-10-26 at 13:05 -0400, Regina Obe wrote:
> Hey all. So we've been in talks with our editor about having a 3rd
> Edition
> of PostGIS hopefully to be released around the same time as PostGIS
> 3.0.
> I think they are more or less sold on the idea except they did ask
> about
> current market share and usage.
> Part of the reason for that is our previous editions focused a lot
> on "How
> do I use this function or do this weird sounding thing that only GIS
> people
> can make sense of" instead of "How do I do this real world thing"
> So one of the thoughts was having our table of contents be more like
> "How do
> I do this with PostGIS" in somewhat laymen terms that most people can
> relate
> to - like Political Districting, Real Estate analysis (walk scores,
> elevation measurements to determine viablility of building on a plot
> of
> land)
> without scaring people off with "real world things" they can't
> relate to or
> in overly techy terms.
> Also since the 2nd Edition (which was in 2015 super ancient now since
> the
> New shiny version at the time was 2.1 and 2.1 is not even supported
> anymore).
> Other major thing changed is a lot of people are deploying PostGIS on
> cloud
> offerings like Amazon RDS, Microsoft Azure, and Google PostgreSQL for
> Cloud
> so we plan to cover a bit about some things relevant in those that
> may not
> be relevant when deploying on your own server.
> That said, if people can respond with what things they are currently
> using
> PostGIS for and also what hosting they are using for PostGIS, that
> would be
> helpful for us to get a better idea of focus points.
> It'd be great if you posted on the list, but if you are shy or need
> your
> usage anonymized, you can write directly to me.
> Thanks,
> Regina
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
