[postgis-devel] postgis, postgis-raster: ready ?
Sandro Santilli
strk at kbt.io
Thu Sep 6 07:23:11 PDT 2018
On Wed, Sep 05, 2018 at 05:20:17PM +0200, Sandro Santilli wrote:
> On Mon, Sep 03, 2018 at 12:06:35PM -0400, Regina Obe wrote:
> > -1, maybe I'll change my mind later but we've got other serious issues in postgis 3.0 like lots of bots failing.
> I ticketed ONE reason for bots failing:
> https://trac.osgeo.org/postgis/ticket/4170#ticket
> Dronie is catching an upgrade issue: our upgrade mechanism
> refuses to soft-upgrade from 2.x to 3.x (did we have a policy
> about naming versions to only increment Major for dump/restore
> requirements?)
I've fixed the upgrade issue so now Dronie is happy.
Bessie, Bessie32, gitlab-ci and Travis are also
all happy.
I suspect Debbie and Winnie are the usual bot-side
misconfiguration (sorry I got lost in clicks so wasn't
able to really find out what the failure was about).
At this point it should be easy to tell if the
raster-split breaks anything new, right ? Is this
enough to retire your veto ?
--strk;
