[postgis-devel] Union/Collect/Aggregates
Raúl Marín Rodríguez
rmrodriguez at carto.com
Tue Apr 30 03:31:04 PDT 2019
> - Memory free on cancellation: let's check how it really works.
Agree, let's check first before modifying everything yet again. Also,
if the process is closed when the query is cancelled the memory
will be returned to the OS automatically.
OTOH, if the process outlives the query, then the leak is masive.
> Can GEOS live in palloc'd memory?
Technically doable, if just requires quite a bit of work in GEOS.
carto.com
