[postgis-devel] contrib new postgis function
Emilson Ribeiro Neto emilsonribeiro at hotmail.com
Thu Aug 22 08:07:58 PDT 2019
Dears,
After a specific demand in my work I needed to develop a function to create a single space line from two untouched geometries.
Following is code below if it is interesting to put as new functionality in postgis.
best regards
CREATE OR REPLACE FUNCTION public.st_mergecloselines(
geometry, geometry)
    RETURNS geometry
    LANGUAGE 'sql'
-- This function merge two lines that don't within (dont touching) returing a single multiline. By Emilson Ribeiro Neto
AS $BODY$
select ST_LineMerge(st_union(st_union($1,
(case
  WHEN (st_distanceSphere(ST_StartPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_StartPoint($1),ST_EndPoint($2))
                and (st_distanceSphere(ST_StartPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_EndPoint($1),ST_StartPoint($2)))
                and (st_distanceSphere(ST_StartPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_EndPoint($1),ST_EndPoint($2)))
              ) THEN st_makeLine(ST_StartPoint($1),ST_StartPoint($2))
  WHEN   (st_distanceSphere(ST_EndPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_StartPoint($1),ST_EndPoint($2))
                and (st_distanceSphere(ST_EndPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_StartPoint($1),ST_StartPoint($2)))
                and (st_distanceSphere(ST_EndPoint($1),ST_StartPoint($2)) < st_distanceSphere(ST_EndPoint($1),ST_EndPoint($2)))
              ) THEN st_makeLine(ST_EndPoint($1),ST_StartPoint($2))
  WHEN   (st_distanceSphere(ST_StartPoint($1),ST_EndPoint($2)) < st_distanceSphere(ST_StartPoint($1),ST_StartPoint($2))
                and (st_distanceSphere(ST_StartPoint($1),ST_EndPoint($2)) < st_distanceSphere(ST_EndPoint($1),ST_StartPoint($2)))
                and (st_distanceSphere(ST_StartPoint($1),ST_EndPoint($2)) < st_distanceSphere(ST_EndPoint($1),ST_EndPoint($2)))
              ) THEN st_makeLine(ST_StartPoint($1),ST_EndPoint($2))
            else  st_makeLine(ST_EndPoint($1),ST_EndPoint($2))
            end)),$2))
$BODY$
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190822/89c475df/attachment.html>
