[postgis-devel] Proposal: Adding buffer parameter to ST_TileEnvelope()
Regina Obe lr at pcorp.us
Sat Dec 7 10:26:11 PST 2019
I assigned Paul, Raul, Sandro, and Darafei for feedback.
I don’t have too many opinions about it.  If Raul is fine with it, I’m fine with it :)
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Yuri Astrakhan
Sent: Saturday, December 7, 2019 12:42 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Proposal: Adding buffer parameter to ST_TileEnvelope()
What should the next steps be to get https://github.com/postgis/postgis/pull/514 merged?  Are there any blockers or required TODOs?  Thanks!
On Thu, Nov 14, 2019 at 2:29 PM Yuri Astrakhan <yuriastrakhan at gmail.com <mailto:yuriastrakhan at gmail.com> > wrote:
How should we grow tiles then with regards to the bounds parameter?  I see two approaches:
* bbox longitude (x) is not clipped unless it grows wider than the bounds, in which case the result spans the whole bounding box. Latitude (y) is always clipped.
    PROs: makes it possible to use with geometry columns without any extra modifications.
    CONs: might cause confusion because the result could be outside of bounds, and because it might not match geometries across antimeredian.
* bbox grows up to the bounds, and then gets clipped.
    PROs: all generated bboxes are within the bounds, using it as filter always matches real data in the geometry columns.
    CONs: have to manually extend it across antimeredian if needed.
I'm inclined to go with the first approach, would that be ok?
On Thu, Nov 14, 2019 at 7:58 AM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca> > wrote:
On Nov 13, 2019, at 11:35 PM, Yuri Astrakhan <yuriastrakhan at gmail.com <mailto:yuriastrakhan at gmail.com> > wrote:
Rough implementation PR - https://github.com/postgis/postgis/pull/514
I am having some issues with unit tests (too much magic in auto-generated code?), so a Postgis guru's help might be needed.
One open concern: extending envelope beyond antimeredian. Is this possible? Would a bbox from the tile that overflows to the other side of antimeredian match any geometries? For example, given two points - one at -179, and the other is at +179 (longitude), would they be found with the bbox that goes from -200..-160 ?
In geometry they would not match, in geography they would.
P
postgis-devel mailing list
postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191207/efe5c8ce/attachment.html>
