[postgis-devel] Compile error in postgis-3.0.0dev revision 17232
Sandro Santilli strk at kbt.io
Thu Feb 7 07:56:43 PST 2019
On Thu, Feb 07, 2019 at 07:51:23AM -0800, Bruce Rindahl wrote:
> Thanks - autogen fixed it.  Didn't have to do that before.
You only need to run ./autogen.sh whenever something changes
in the source file genrating the "configure" script.
Always running it when fetching sources from SVN doesn't hurt.
Formal releases will always have it pre-generated for you.
--strk;
