[postgis-devel] Compile error in postgis-3.0.0dev revision 17232
Regina Obe
lr at pcorp.us
Fri Feb 8 15:05:19 PST 2019
We should probably put it in the docs
https://postgis.net/docs/manual-dev/postgis_installation.html#install_getting_source
I think in the past people just always got their code from tar ball but now that more folks are going to direct to svn or git, we should probably note the bit that you need to run
sh autogen.sh
Bruce – if you are the mood, feel free to update the docs accordingly or I'll do it when I get around to it.
Thanks,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bruce Rindahl
Sent: Thursday, February 07, 2019 11:14 AM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] Compile error in postgis-3.0.0dev revision 17232
Good idea. I'll add it to my build script
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190208/db21a04e/attachment.html>
