[postgis-devel] Benchmark/Testing setup
Brian M Hamlin maplabs at light42.com
Tue Feb 19 10:14:15 PST 2019
Hi Bruce -
  Thanks for this opportunity to look more carefully at a crucial topic ..
Please document the BASE_OS, PostgreSQL_VERSION, postgres conf
settings, versions of dependent libs and
hardware involved .. tablespace physical disk, RAM, CPU model..  Its a
bit of work, but important !
  from that base, the PostGIS BRANCH and VERSION can be varied.
Perhaps PostgreSQL itself as well.
The values there might be recorded in some tabular format, including
the results -> per test suite.
You probably know about the fine site
https://explain.depesz.com/    which can add detail to your EXPLAIN
findings.
  best regards from Berkeley, California
   --Brian
On Tue, 19 Feb 2019 09:59:12 -0800, Bruce Rindahl
  wrote:
       I now have my cluster setup for testing with multiple small
computers with a full PostgreSQL/PostGIS installation.  Using this I
ran some quick tests to find what cost on the ST_Area function kicks
into parallel mode.  Using data/queries by Paul Ramsey
at:http://blog.cleverelephant.ca/2017/11/parallel-postgis-2A.html
It kicks into parallel mode at cost = 66.  I can easily test other
functions/configuration.
 If this can help, let me knowThanks
Bruce
postgis-devel mailing list
postgis-devel at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-devel
Brian M Hamlin
OSGeo California
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190219/9ef82e57/attachment.html>
