[postgis-devel] [postgis-users] ST_Maxdistance schema hardcoding error
Regina Obe
lr at pcorp.us
Fri Jul 12 16:05:35 PDT 2019
How did you move the extension?
And which version are you running. Since 2.3, PostGIS functions are schema qualified.
The easiest way is to force a reinstall.
ALTER EXTENSION postgis UPDATE;
Should work if you are not running the latest version (one listed in your postgis.control).
If it gives you an error something like
NOTICE: version "2.5.2" of extension "postgis" is already installed
Then you can do what I call the yo-yo hack
ALTER EXTENSION postgis UPDATE TO "2.5.2next";;
Followed by
ALTER EXTENSION postgis UPDATE TO "2.5.2";
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Philip M. Hurvitz
Sent: Friday, July 12, 2019 2:53 PM
To: postgis-users at lists.osgeo.org; postgis-devel at lists.osgeo.org
Subject: [postgis-users] ST_Maxdistance schema hardcoding error
Hi all, I found that ST_MaxDistance() was failing for a database that had the PostGIS extension installed in the schema 'postgis'.
SELECT ST_MaxDistance('POINT(0 0)'::geometry, 'LINESTRING ( 2 0, 0 2 )'::geometry);
ERROR: function public.st_convexhull(geometry) does not exist
LINE 1: SELECT public._ST_MaxDistance(public.ST_ConvexHull($1), publ...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT public._ST_MaxDistance(public.ST_ConvexHull($1), public.ST_ConvexHull($2))
CONTEXT: SQL function "st_maxdistance" during startup
Time: 147.448 ms
It seems that the function is expecting to find the ST_ConvexHull function in the public schema.
As a workaround I edited the code for the _ST_MaxDistance and ST_ConvexHull to create identical functions in the public schema and now things work as expected:
st_maxdistance
2
I had originally installed PostGIS in the public schema but then relocated the extension to the postgis schema -- could this be the reason? Other functions are acting strangely, e.g., postgis_version works OK
select postgis_version();
postgis_version
2.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
but postgis_full_version fails
select postgis_full_version();
ERROR: function public.postgis_lib_version() does not exist
LINE 1: SELECT public.postgis_lib_version()
QUERY: SELECT public.postgis_lib_version()
CONTEXT: PL/pgSQL function postgis_full_version() line 25 at SQL statement
Does anyone know if there is a fix for rewriting the functions that are looking in public for functions that are located in the postgis schema?
Thanks for any info!
_____
Philip M. Hurvitz
Research Assistant Professor, Urban Design and Planning
Research Scientist, Civil Engineering (TRAC)
http://gis.washington.edu/phurvitz/contact
_____
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190712/451fe872/attachment.html>
